EAGLE User Support (English) Broken Ground Plane
  • Views 696 views
Broken Ground Plane
(EAGLE 5.10) I have a 4-layer board I've been working on for months that
last night, as I was finishing the layout, the ground plane polygon on
layer 2 quit pouring properly & instead seemed to connect every pin & via
on the layer w/the only reliefs appearing around drilled holes (not pads)
exclusively. I do see thermals & isolation rings in the layer but the pour
is solid & covers everything. (confirmed via gerber file) Grid is 0.1",
width is .008", pour is solid, spacing is .05", isolate is 0, rank is 1 &
thermals is checked. I'm using the exact same settings on the power planes
(layer 3) which are still pouring just fine. What next? The brd file at
110K is too big to post here but I'll send it to anyone who wants to see
it. Thanks in advance
    Am 02.03.2013 17:30, schrieb darms:
    Joern, I get it! Putting a polygon on a supply layer confuses the CAM
    processor & truly mucks up the display if the polygon is smaller than the
    board outline. Which is what I did Thursday night, resize the polygon on
    layer 2. Just for grins I just now deleted the ground polygon & re-ran the
    CAM processor, the ground plane was there in all of its glory albeit the
    size of the full board outline! Subtle, eh? Thanks again for your help, I
    completely missed this one (& have been using EAGLE for years, but this is
    my first multi-layer board with this software). Yea, EAGLE Central Forums!
    Yeah, sometimes *** happens. Glad I could help image
    Joern Paschedag
    Wow, Joern, unselecting supply layer worked, thank you so much! Not only
    would I have never found this on my own, I have no idea how the box was
    checked in the first place unless I checked it back in Sept. when the
    layout started. But I didn't start having pour problems until two nights
    ago, hmmm... But again, thank you very much for helping!
    Am 01.03.2013 18:35, schrieb darms:
    IMHO you have selected layer2 as a supply layer "$gnd".
    You must remove the "$" sign:
    Display layers, mark layer2, select "change" then remove the hook from
    "supply layer" that should do the job image
    Joern Paschedag
    Here's the board
    that last night, as I was finishing the layout, the ground plane
    polygon on layer 2 quit pouring properly & instead seemed to connect
    every pin & via on the layer w/the only reliefs appearing around
    drilled holes (not pads) exclusively. I do see thermals & isolation
    rings in the layer but the pour is solid & covers everything.
    (confirmed via gerber file) Grid is 0.1", width is .008", pour is
    solid, spacing is .05", isolate is 0, rank is 1 & thermals is
    checked. I'm using the exact same settings on the power planes (layer
    3) which are still pouring just fine. What next? The brd file at 110K
    it. Thanks in advance --
    ZIP the file and it will be small enough to post
    news.cadsoft.de
