EAGLE User Support (English) ULP naming on inner layers
  • Views 420 views
Top and bottom layers can be referred to by the built in constants
LAYER_TOP and LAYER_BOTTOM but how do you refer to inner layers?
Thanks.
Keith
    autodeskguest over 13 years ago in reply to e14 Contributor
    On 22/02/2013 06:21, Warren Brayshaw wrote:
    Keith
    Now I see what you are asking.
    There are no constants for the inner layers. LAYER_TOP and LAYER_BOTTOM are
    integer constants that return 1 and 16 respectively. That equates to their
    layer numbers so just test for layer numbers or make up you own. Personally
    in a ULP I simply test LAYER.NAME = = 2 or what ever I'm interested in .
    HTH
    Warren
    Warren,
    Thanks.  I was coming to the conclusion that there weren't built in
    constants for the other layers.  I need to read a bit more about the ULP
    language to try to achieve what I want.
    Keith
    Keith Raper wrote:
    On 24/01/2013 18:18, Warren Brayshaw wrote:
    Keith Raper wrote:
    Thanks.
    Keith
    Route2
    Route15
    See HELP LAYER or the manual
    Warren,
    Thanks for the reply but that doesn't work.  The error is "unknown
    identifier 'Route2'".  If you use "LAYER_ROUTE2" you get "unknown
    identifier 'LAYER_ROUTE2'" (and for pretty much any combination I have
    been able to think of).
    I haven't been able to find anything in the help or the manual about
    how to refer to the inner layers in a ULP.  For some reason it
    doesn't seem to be the same as "name" or "Layer_name" normally used
    to refer to the layer, even though "layer_top" and "layer_bottom"
    works.
    Keith
    HTH
    Warren
    news.cadsoft.de
    Keith Raper wrote:
    Thanks.
    Keith
    Route2
    Route15
    Warren,
    I haven't been able to find anything in the help or the manual about how
    to refer to the inner layers in a ULP.  For some reason it doesn't seem
    to be the same as "name" or "Layer_name" normally used to refer to the
    layer, even though "layer_top" and "layer_bottom" works.
    Keith
    Keith Raper wrote:
    Thanks.
    Keith
    Route2
    Route15
    news.cadsoft.de
