EAGLE User Support (English) Making the switch from expressPCB - ground plaine
  • Views 760 views
    I'm working on making the change from expressPCB and there are some things I'm wondering how to do or if they're possible.
It's nice to be able to hide the ground plaine while working so it's easier to see traces, connectors, labels, etc.  Is there an easy way to hide the pologon?
Also, is there an easy way to move around the part lables so it doesn't get so muddled with parts that are close together?
Thanks!
Mike
    This is good while designing, but the silk screen keys off of the Names and Values.  So it's preferable for me to remove or move the names or values so they don't end up on the silk screen if I don't want them to, or those names that I want on the silk screen are placed correctly.
    That's certainly one way to do it, but a quicker (and reversable) method is to simply turn off the layer you don't want to see.
    Go to:
    View -> Layer settings
    or
    select the 'layer settings' icon from the Command Button menu
    and de-select:
    layer 16 - bottom copper
    layer 25 - top Names
    layer 27 - top Values
    etc.
    ian
    Figured it out again.  Use "Smash" on the component and then you can select, move, delete labels on the component.
    Found my answer here:
    http://arduino.cc/forum/index.php?topic=50535.0
    In the command window at the top, enter "ripup @" and that will make the pur dissapear.  If you hit ratsnest again, it will appear.
    Still figuring out how to move the part lables.
    Thanks!
    Mike
    http://www.element14.com/community/message/69107#69107/l/making-the-switch-from-expresspcb--ground-plaine
    Hi Mike,
    To revert the polygons to outline mode type:
    ripup @;
    Followed by enter in the EAGLE command line, the polygons will now be
    unfilled and you can see your traces clearly.
    To move around component labels you first seperate the text from the
    part using the SMASH command. You will now notice that the text have
    little cross hairs on the bottom left edge. You use these snap points to
    move and modify the text with the appropriate commands.
    Best Regards,
    Jorge Garcia
