EAGLE User Support (English) Very simple, very wanted GRID feature
  • Replies 8 replies
  • Views 743 views
  • duble
  • half
  • grid
  • divide
Hi
I often work on boards with big difference in size of components.
This involves changing the grid size all the time.
The only thing i need is to be able on a hotkey to duble and half grid.
No need for gui parts just the command eg. GRID MUL2 and GRID DIV2
NOT to be confused with the multiplier in the grid menu that only changes the displaying in multiplums
I tryed to make a hot key for the grids i use the most but it becomes alot of keys to remember
insted of just two and i ended up back to changing in in the menu...
I belive that there was the posibility in some old version in the form of two buttons under grid settings but i am no sure.
I remember being anoid about a change in that menu...
As a programmer I cant see this taking more than an hour to implement and perhaps another to test posible problems.
Keep up the good work
I have been using Eagle more or less daily both in the free and pro version for some 10 years now.
And like it very much especially the going to XML format since this has opend op for using software dev. versioning tools like GIT, SVN or CVS.
We allready moved all our eagle projects in to GIT repositorys, meaning perfect version history throughout the project. Also takes care of merging
Librarys when two persons have added a component be fore sync'ing.
Best regards
Asbjørn Holland Christensen
Musalk
    autodeskguest over 13 years ago in reply to e14 Contributor
    In article <khdcnp$73d$1@cheetah.cadsoft.de>,
    warrenbrayshaw@paradise.net.nz says...
    You wont see attachments at Element14. Its a poorly implemented  front end
    to the news group.
    Use Eagle Central which is a far better front end.
    Here's the link to my post ...
    I'm so glad someone else agrees with me about this.
    I've stopped strugling with element14 altogether.
    Talk about spam filled confusion. I found it
    impossible to get anywhere with it.
    I didnt know there was an alternative - thank you.
    Asbjørn Holland Christensen wrote:
    Already done. Andreas Weidner (+Rowena Fermi) offered up the
    attached way back.
    Just assign these ULP to keys.
    Warren
    Attached ?
    http://www.element14.com/community/message/71542#71542/l/re-very-simple-very-wanted-feature
    to the news group.
    http://www.eaglecentral.ca/forums/index.php/m/150027/2ee7268b0227c943a42a5c1af50670e2/#msg_150027
    Warren
    news.cadsoft.de
    Already done. Andreas Weidner (+Rowena Fermi) offered up the attached way
    back.
    Warren
    Attached ?
    How about alias?
    Well it is essentialy the same as defning a hot key with the parameters.
    Must say I did not enter my mind to use ULP to do it.
    Also did not spend any time on getting into that langauge.
    Anyway it was a sugestion for future release since i belive it is better to have
    native functions rather than every body sitting with there own ulp modyfied version.
    Not to say i dont love the consept of ulp to expand with special functions.
    Best regards
    [quote
    then go ahead and write yourself a small ULP to do the job?
    Lorenz
    back.
    Warren
    Am 06.03.2013 23:35, schrieb Asbjørn Holland Christensen:
    Hi
    Best regards
    Musalk
    http://www.element14.com/community/message/71374#71374/l/very-simple-very-wanted-feature
    How about "alias"?
    Joern Paschedag
    Lorenz
