EAGLE User Support (English) Empty project
  • Views 377 views
Empty project
I have a project I am working on, all is normal EXCEPT the control panel
says empty project...WHY?
When I click on it, it brings up both my board & schematic & the green dot
just fine. Closing, it, exiting Eagle, trying again, etc, gives the same
result, with "empty project".
This is rather disconcerting, since it is NOT empty.
Finally, I noticed I could edit the description & all is now well (now
gives MY description), but why would it have been saying empty project?
This is Version 6.4.0
    I should sayat the top of the control panel directory list are several
    V5.xx projects that I have not converted to the new V6.xx ( I open it asks
    if I want to save in the new format, which I have been saying "NO", since
    I'm not working on them now)...not sure if this has any effect on my V6
    project at the bottom of the list.
