EAGLE User Support (English) A problem with routing
  • Replies 8 replies
  • Subscribers 187 subscribers
  • Views 710 views
people here at the newsgroup helped me a couple of times once ago so I
thought someone might know if there is a way to avoid the bends on
these two traces (marked with the arrows):
http://img594.imageshack.us/img594/4174/howtoroute.png
The routing grid is 10 mils because I have SMD elements. Is there
something I could do with these two traces or should I just leave them
as they are?
Chupo
    autodeskguest over 13 years ago in reply to autodeskguest
    In article <kio27v$u0j$1@cheetah.cadsoft.de>, Warren Brayshaw
    <warrenbrayshaw@paradise.net.nz> says...
    Sorry, I missed the next step. 'Then move (click the end of the wire) to
    correct any slope errors that were introduced'.
    4 clicks and the job should have been done.
    Yes, that worked as well - thank you very much for your help!
    Best regards
    Chupo
    AM2 wrote on Mon, 25 March 2013 07:02
    In article <kiltu8$6n4$1@cheetah.cadsoft.de>, Warren Brayshaw
    There is no need to change them as the drill goes right through
    them. That
    said  you can improve the look. Just MOVE the larger traces that
    bend at the
    last moment
    Select MOVE, click the middle of the large traces  and you can move
    them to
    the next grid line which looks like it would be perfect.
    That way I got the traces that were nearly perfect at the switch pad
    place but moving the large trace changed the slope on the left hand.
    All the best
    Warren
    There is no need to change them as the drill goes right through them. That
    said  you can improve the look. Just MOVE the larger traces that bend at the
    last moment
    Select MOVE, click the middle of the large traces  and you can move them to
    Starting the trace from the switch pad, as suggested by Richard, solved
    the problem.
    However, it seems I don't need to route the bottom pad since it can be
    connected to GND via the ground plane. I think I'll have another
    question regarding autorouting with GND planes. The question is how to
    instruct autorouter not to route all of the GND traces since some of
    the pads could be connected to the GND plane thru VIAs (and at the
    moment of routing the traces, the GND plane on the opposite side still
    doesn't exist). I am first going to experimet for a while and then
    probably start another thread with the new subject.
    Thank you for answering!
    Chupo
    In article <op.wuf7y0ms2mc6nl@homer>, Richard Herman
    <bebop@xs4all.remove.nl> says...
    If you remove these two traces and start routing FROM the switch (not to
    it) the copper trace will 'pick up' the grid of the switch en connect
    perfect. You can go back to the other routing grid at the first bend. Just
    experiment a little.
    Yes!! That works just perfect. Thank you very much for your help!!
    Chupo
    In article <kiltm1$5b9$1@cheetah.cadsoft.de>, Paul Romanyszyn
    <pgr@arcelectronicsinc.com> says...
    Options are
    Leave as is
    change to finer grid and move traces or part to be on the grid.
    Then increase trace width and clearances some.
    You mean to increase the overall trace width&clearances? I can't do
    that because of TQFP32 element. I had to use 12 mil traces,
    wire-wire&pad-wire clearances of 10 mils, and 9 mil pad-pad clearance.
    I once ago asked about the mixed width traces:
    http://tinyurl.com/dyq2t3d
    but I think this PCB wouldn't be suitable for using more than one trace
    width.
    Chupo
    Op Sun, 24 Mar 2013 04:02:25 +0100 schreef Chupo <bad_n_mad@yahoo.com>:
    as they are?
    Richard
    Chupo wrote:
    as they are?
    Chupo
    last moment
    HTH
    Warren
    news.cadsoft.de
    On 03/23/2013 11:02 PM, Chupo wrote:
    as they are?
    Options are
    Leave as is
    Paul R.
