EAGLE User Support (English) Naming a wire (net)
  • Views 283 views
Naming a wire (net)
e14candies
e14candies over 13 years ago
I have a few wires (nets) that I'd like to give names to (such as Vbatt,
PWM_CTL, etc)....then other wires on the same page are given the same names
to establish connectivity between them without a lot of wire clutter.  In
the past, I've added little arrow symbols (as components), but this time
I'd like to name the wires directly for less clutter. Just have the desired
name setting alongside a long wire.
I see that I can do an info on a wire (net) & edit the netname, but the
name is not shown on the schematic.  Am I missing something?  Or maybe you
are forced to add  arrow symbols (components).
  • e14candies
    e14candies over 13 years ago in reply to autodeskguest
    Joern:
    Works great--Thanks very much!
    Am 25.03.2013 07:50, schrieb Hoyt:
    Use LABEL to make  the name visible. Or do a CHANGE x-ref = on and then
    use the label command. You'll see the difference image
    Joern Paschedag
