EAGLE User Support (English) Persistant Highlighting again
  • Subscribers 187 subscribers
  • Views 311 views
on a layout with IC with many ground pins, I am about to place ground
vias. I can highlight the ground pins with "show gnd", but as soon a I start
to place ground vias with "via 'gnd" the highlighted ground pin return to
normal bightness.
A perststant highlight would help much in that situation.
Uwe Bonnes                bon@elektron.ikp.physik.tu-darmstadt.de
Institut fuer Kernphysik  Schlossgartenstrasse 9  64289 Darmstadt
Tel. 06151 162516 -
Fax. 06151 164321 -
    autodeskguest over 13 years ago in reply to autodeskguest
    Yes. Often it would (I often wished back the persistent show from
    previous EAGLE versions), but sometimes it was a nuisance (I often was
    glad that the behaviour changed). Since EAGLE did have the persistent
    highlighting previously, it shouldn't be too much of a problem to
    implement it again.
    sadly it seems to be difficult, read Klaus Schmidinger in
    eagle.betatest "Re: highlighting after show disapears [ was: feedback
    for 5.2.2 ]" dated 2008-09-16, Message-ID:
    <gao7gd$kg3$1@cheetah.cadsoft.de>
    |With the old version, objects were drawn directly to the window area, while
    |with the new version we need to redraw rectangular areas of the window in
    |a background pixmap and draw that whole rectangle onto the window - which
    |may be larger than an individual object, for instance in case of a 45 degree
    |wire. Therefore, while in the old version we could just leave the highlighted
    |objects on screen even after SHOW had ended, this is no longer feasible now.
    |There are plans to change the handling of highlighted objects, but this
    |will most likely require an incompatible change to the data structures.
    Oliver
    Oliver Betz, Munich
    despammed.com is broken, use Reply-To:
    Am 27.03.2013 11:22, schrieb Uwe Bonnes:
    normal bightness.
    implement it again.
    In order to let the user decide what behaviour fits best, I suggest a
    settable option like
       SET PERSISTENTSHOW 0;
    and
       SET PERSISTENTSHOW 1;
    (with the default being 0)
    The former would behave as implemented now, the latter as implemented
    previously. This way, one could use the best of BOTH worlds.
    Andreas Weidner
    normal bightness.
    +1
    Oliver
    Oliver Betz, Munich
