EAGLE User Support (English) layers self-show
  • Subscribers 189 subscribers
  • Views 325 views
layers self-show
e14candies
e14candies over 13 years ago
I am routing a board with through hole and also SMDs on both sides.  I am
working now on the bottom.  To make things readable I've turned off all of
the top layer stuff, since I'm only interested in routing some smd items on
the bottom.
In one case I need to connect from a through hole via to a bottm pad.
However, when I click on the via all the top layer stuff turns on making
the screen too garbled with information to see clearly.
I want to turn off the top layer view items and STAY OFF...can this
automatic turning-on be stopped?
    autodeskguest over 13 years ago in reply to e14candies
    Hoyt wrote:
    6.4 on windows 7
    Can you prevent the layers from turning on?
    Part of the problem may be it turns on the top layer and points an
    airwire to a top location that is closer to the smd pad on the
    bottom(if a via is to be added).  However, I already have vias on the
    bottom that I want to connect over to, I'm not wanting to add more
    vias when something is available and almost as close already.
    I have pads & vias on the bottom, I just want to connect them, with
    the top stuff turned off!
    This does not happen for me.
    With top layers turned off I can route an SMD on the bottom to a via that is
    connected to the top layer. Additionally I can route on the botttom layer
    between a via and a pad.
    Layer Top does not turn on.
    You may be starting to route with the layer 'Top'  selected. Ensure that
    before you start to route, the 'Bottom' layer is selected (not just
    displayed). Use the tool bar that reveals itself when you select route.
    HTH
    Warren
    news.cadsoft.de
  • e14candies
    6.4 on windows 7
    Part of the problem may be it turns on the top layer and points an airwire
    to a top location that is closer to the smd pad on the bottom(if a via is
    to be added).  However, I already have vias on the bottom that I want to
    connect over to, I'm not wanting to add more vias when something is
    I have pads & vias on the bottom, I just want to connect them, with the top
    stuff turned off!
  • bmoe
    bmoe over 13 years ago
    Which Eagle version and operating system are you using?
