EAGLE User Support (English) Technology and package
  • Replies 9 replies
  • Subscribers 187 subscribers
  • Views 806 views
EAGLE assumes that any part name is composed in the following way:
BASE_NAME|TECHNOLOGY|PACKAGE
some parts come with another order:
BASE_NAME|PACKAGE|TECHNOLOGY
How to handle this?
Marco
    autodeskguest over 13 years ago in reply to autodeskguest
    Marco Trapanese schrieb:
    In the past I did exactly that.
    It was fine until I had to go in production. Who mounts the boards ask
    me not only the part value but also the order codes from suppliers
    (Farnell, Mouser, Digikey).
    I store them in the attributes and the BOM is ready in a while.
    Following your method I must write the order codes every time by hand.
    Yes. However, very many standard components don't require special order
    codes for particular suppliers - you buy them where you get them (or
    where you place an order anyway). So creating a BOM isn't that hard (we
    also use an ULP that does most of the work). There always are only a few
    parts that really need to be specified in more detail.
    Otherwise, you need trillions of different devices for basically the
    same part. Just one more example: a simple 470/35 capacitor, for me it's
    just a 10 mm diameter part. Depending on the circuit, it needs to be a
    standard capacitor (brand doesn't matter), or some special low-ESR type,
    or eventually a special high-temperature type. Sometimes, height also is
    an issue. Using attributes and order codes, you'd need about a dozen
    different devices just for this single capacitor (and the same amount
    for every other C/U combination) - while opposed to this, our generic 10
    mm device suits about a dozen different C/U combinations including all
    particular types and brands (which are remarked in the value, if necessary).
    Finally, it's your decision if you want to put more effort on creating a
    BOM - or on maintaining bloated libraries and keeping the design files
    in sync with them.
    Tilmann
    Il 08/04/2013 16:45, René König ha scritto:
    this is done through naming the part as needed. The placeholder for
    TECHNOLOGY is '*' and the placeholder for PACKAGE is '?'. See:
    HELP TECHNOLOGY
    HELP PACKAGE
    Glad the hear this.
    I'm going to see those pages.
    Marco
    Il 08/04/2013 15:10, Tilmann Reh ha scritto:
    That's exactly what is not necessary.
    Different temperature ranges, different regulator voltages etc. can
    perfectly be handled just with different VALUES.
    For example, a generic voltage regulator is "78xx", for any 7800 series
    (or similar) three-pin positive regulator - with package variants for
    TO220 (vertical and horizontal), TO92, DPAK, D2PAK etc..
    In the schematic, simply pick it (with the right package variant), then
    assign the proper value (like 7805, 78L12 - or even LP2950-3.3).
    Or, for TVS diodes: we use one single device, with a few package
    variants (some common THT sizes, SMA, SMB, SMC) - and then set a proper
    value (like P6SMB15CAT3GP6SMB15CAT3G, for example).
    Am I wrong?
    Marco
    And the ATTRIBUTEs are probably different as well, or do you even have a
    generic ATTRIBUTE-set? Or don't you use ATTRIBUTEs at all? I simply
    cannot imagine me entering all the necessary ATTRIBUTEs over and over
    again...
    Exactly: I also don't use attributes at all.
    KISS principle.
    Tilmann
    Am 08.04.2013 15:10, schrieb Tilmann Reh:
    That's exactly why this is needed.
    again...
    Rene
    HELP TECHNOLOGY
    HELP PACKAGE
    Rene
    IMHO, the "technology" is absolutely senseless/useless anyway. You get
    the same effect just by setting a proper VALUE.
    So all my libraries contain devices that are as generic as possible, and
    none of them uses "technology". When putting them into the schematic, I
    assign a meaningful value, and all is done.
    My experience is different than yours. The technology field (since EAGLE
    supports the "append" features for pin/pad) is very useful for me to
    take care of the small differences among parts.
    For example the C/I designator for temperature ranges is properly
    handled with the technology fields, allowing you to have ONE part in the
    library. Or think about an LDO or TVS family: they could have dozen of
    different voltages. Each one with its own order code.
    If you don't use the technology fields you must create a different part
    for every variant!
    Of course you need to take care - don't assign an LP2950 to a TO220
    package. But as developer, you need to take care anyway, and for much
    more subtle details...
    The best would be to define the "part name" according to the
    manufacturer specifications. But I admit this could be quite complex to
    implement.
    No, it's quite easy: use the part name provided by the manufacturer AS
    VALUE.
    Tilmann
    for every variant!
    implement.
    Marco
    How to handle this?
    Tilmann
