EAGLE User Support (English) Display Pad Names
  • Subscribers 187 subscribers
  • Views 1686 views
Display Pad Names
I would like to ask you why, the SET PAD_NAMES ON/OFF command or in the
Menu:
Options -> Set->Misc->Display Pad Names, doesn't show the pad names in the
schematic editor?
Thanks for answer
Tom
    autodeskguest over 13 years ago in reply to autodeskguest
    Hi Jorge,
    thanks for your answer. Yes I know that it works in this way, but it is
    little bit "painfull" to edit every part and every pin in library, just if
    you only want to check in schmatic editor if evrithing in library is done
    in right way. When you print it it will be also shown and you can't turn it
    of globally. It will be nice if this option will works in schematic editor.
    For example, it is necessary if you have to convert and make consistent
    some eagle projects from Eagle version 2 image Also it will be very
    nice/helpfull if the pin name in symbol could be smashed.
    Tom
    On 4/15/2013 7:01 AM, Tom wrote:
    Menu:
    schematic editor?
    Thanks for answer
    Tom
    Hi Tom,
    When creating a part in the library it's possible to specify whether pad
    names are displayed or not in the schematic editor. In some cases
    (resistors)it doesn't make sense to display pad names in the schematic
    symbol, hence why the option is defined in the library. It's easy to set
    look at the properties of a pin and you'll see the visible parameter
    which allows you to select whether you want both the pin and pad name,
    neither, or one of the two to be displayed.
    The SET PAD_NAMES ON/OFF option only applies to the layout.
    Let me know if you need further clarification.
    Best Regards,
    Jorge Garcia
