EAGLE User Support (English) need bare copper
  • Views 1592 views
need bare copper
e14candies
e14candies over 13 years ago
I defined a reactangle  & also a rather strange shape polygon on layer 1
(with 100 mils clearance.  They both show up as red, just fine.  However,
since these are heat sinks, I do not want them to be covered with anything
such as soldermask..I want bare coipper here (or perhaps with solder
reflow. How do you specify this when drawing the polygon or rectanlge?
    autodeskguest over 13 years ago in reply to e14candies
    On 22/04/13 03:29, Hoyt wrote:
    ..is there an easy way to copy this exactly on the mentioned
    layer...my polygon has many vertices.
    so how can you get the exact same polygon on different layers?  Is
    there a way to copy it from one layer to another?
    The "clone" tool will duplicate a polygon complete with all vertices
    (but moved if you want). Then the copy can be put on a different layer
    using "change layer". There are some limitations on what you can do that
    to, though. Possibly you may not be allowed to change from copper to
    non-copper.
    Hi
    There are two ULPs that can assist here. Check out:
    copy-layer-to-any-layer.ulp
    copy-wire-to-solder-mask.ulp
    Eagle wont copy from a signal layer to a non signal layer so these ULPs get
    around that by analysing, say, your top layer and rebuilding it on a non
    signal layer.
    Warren
    news.cadsoft.de
  • e14candies
    ..is there an easy way to copy this exactly on the mentioned layer...my
    so how can you get the exact same polygon on different layers?  Is there a
    On 04/21/2013 04:23 PM, Hoyt wrote:
    Draw the same shape on a 'stop' layer,
    ...is there an easy way to copy this exactly on the mentioned layer...my
      Also, the filled polygon has a much different "shape" than the drawn
    polygon due to the electrical clearance to adjacent traces, pads, vias,
    etc.  I only want bare copper for the filled (copper) area, not the total
    polygon border.
    Consider that bare copper has low emissivity
    http://www.engineeringtoolbox.com/emissivity-coefficients-d_447.html
    Having the mask over the copper will increase emissivity.
    So only remove the mask where you have the heatsink touching the board.
    Paul R.
  • e14candies
    polygon border.
    Op Sun, 21 Apr 2013 21:21:39 +0200 schreef Hoyt <nnovotney@cinci.rr.com>:
    anything
    Draw the same shape on a 'stop' layer, tStop in your case. Highly
    adviseable to check results with a Gerber viewer, to catch errors.
    Richard
