EAGLE User Support (English) Bug report: Alt grid Version 6.4.0 for Li nux
  • Views 218 views
On 6.4.0 for Windows, fine positioning with the ALT key works as described
in the manual:
1. Click on MOVE icon
2. Click on object picks it up
3. Hold ALT key while positioning object (activates alternative grid)
4. Click (still holding ALT key) to place part
On 6.4.0 for Linux, the ALT-click (#4) is ignored.  If I release the ALT
key, then click, the object gets placed on the coarser grid.
-Dan
  • dukepro
    dukepro over 13 years ago
    in the manual:
    -Dan
    Dan,
    This is not eagle - it's the window manager.  The problem is that the
    window manager is intercepting Alt-clicks and acting on them.  You'll
    have to modify the specific manager's settings such that alt-clicks will
    be ignored by the window manager and passed on to the application.
    I'm using KDE on opensuse.  Go to System Settings => Window Behavior,
    and select "Window Behavior" from the list on the left and select the
    Window Actions tab.  In the lower panel titled "Inner Window, Titlebar &
    Frame", change the all actions for the Alt key to "Nothing".
    You'll have variations on this depending on which window manager and
    version you're using.  The bottom line is that you'll have to get the
    window manager to pass Alt-clicks to the application.
    HTH,
        - Chuck
    autodeskguest over 13 years ago in reply to dukepro
    described
    in the manual:
    grid)
    ALT
    -Dan
    Dan,
    will
    HTH,
    - Chuck
    That did the trick.  FYI in Openbox that's in:
    ~/.config/openbox/rc.xml
    I commented out the "A-Left" lines under .
    -Dan
    described
    in the manual:
    grid)
    ALT
    -Dan
    Dan,
    will
    HTH,
    - Chuck
    -Dan
