EAGLE User Support (English) SD Card Connector
  • Subscribers 187 subscribers
  • Views 1058 views
SD Card Connector
I need to use a Hinged Micro SD Card Connector with a card-detect (CD)
switch.  A suitable part is the Hirose DM3CS-SF and I have managed to find
an Eagle part for this (see attachment).  However, in common with a few
other Eagle parts for SD Card holders with CD switches, there are no
connections for the CD switch or the ground on the schematic symbol.  All
the pads are visible in the board component.  I realise that I can edit the
part as necessary but I wonder why the part is not complete and whether
there is something I am not realising?
Thanks for any assistance,
paradigm
    Thanks for your assistance Warren.
    I think I have managed to amend the Library part to include the CD switch
    contact together with the four ground connections (using the GND@ notation
    as you suggested - very useful!).  It was not too clear from the datasheet
    which pad was the CD switch.  Only this morning I received some samples and
    could see that the CD switch contact is in fact on pad 11.  Pads 9, 10, 12
    and 13 are the GND connections.  Although it still needs to be verified I
    have attached the complete amended Library part in case anyone wants to
    look at it.  I should have given it a different name but was not confident
    in how to do this with the various component parts.  The Hirose DM3CS-SF is
    the only micro SD card holder I can find with a CD switch and it looks to
    be an impressively high quality item.
    Alan
    find an Eagle part for this (see attachment).  However, in common
    with a few other Eagle parts for SD Card holders with CD switches,
    there are no connections for the CD switch or the ground on the
    schematic symbol.  All the pads are visible in the board component.
    I realise that I can edit the part as necessary but I wonder why the
    part is not complete and whether there is something I am not
    realising?
    paradigm
    Hi Alan
    Maybe most people dont use the hardware card detect, chosing to use the
    signal on the card pin, anyway simply  add the pins 9 thru 13 to the symbol
    and connect them in the device
    10 is the card detect pin as I see it. Name the others ground with the @
    convention (See HELP - PIN)
    HTH
    Warren
    news.cadsoft.de
