EAGLE User Support (English) Eagle 6.4 Pro crashes and out of memory errors with hand routing
  • Views 629 views
skyflyrr
skyflyrr over 13 years ago
I keep getting an "out of memory" error even though my PC shows as having over a gig of free memory. Also started crashing, I assume due to the same memory problem. Any ideas please?
Bob Moreno
  • skyflyrr
    skyflyrr over 13 years ago in reply to autodeskguest
    Jorge,
    Ok done, I'll let you know how that goes.
    Thanks, Bob Moreno
    autodeskguest over 13 years ago in reply to skyflyrr
    On 5/9/2013 10:42 AM, Bob Moreno wrote:
    Jorge,
    Are you referring to the working files when you say install in the docs
    directory? If so, that is where Eagle is installed.
    Bob Moreno
    http://www.element14.com/community/message/76145#76145
    Hi Bob,
    I'm referring to having EAGLE's installation directory in Documents
    instead of Program Files (x86) which is where Windows normally wants
    program to be installed.
    Best Regards,
    Jorge Garcia
  • skyflyrr
    Jorge,
    Are you referring to the working files when you say install in the docs directory? If so, that is where Eagle is installed.
    Bob Moreno
    On 5/8/2013 9:33 AM, Bob Moreno wrote:
    Jorge,
    The OS is Win 7, 64 bit, no special setup, no IT limitations. My PC
    shows lots of available memory, over one gig free. I've had Eagle 6.4
    Pro since release, however this is the first new board I've done and the
    crashes occur during routing. Using same routing control file as prior
    used on Eagle 6.3.Same board specs anyway. The main problem is "out of
    memory" error during hand routing or I say at the start of attempting to
    hand route. I cannot hand route at all. It will auto route.
    Bob Moreno
    http://www.element14.com/community/message/76049#76049
    Hi Bob,
    Please try uninstalling EAGLE and then reinstalling it to the Documents
    directory. I want to try to isolate EAGLE from any Windows 7 craziness.
    Let me know what happens when you do that.
    Best Regards,
    Jorge Garcia
  • skyflyrr
    Jorge,
    The OS is Win 7, 64 bit, no special setup, no IT limitations. My PC shows lots of available memory, over one gig free. I've had Eagle 6.4 Pro since release, however this is the first new board I've done and the crashes occur during routing. Using same routing control file as prior used on Eagle 6.3.Same board specs anyway. The main problem is "out of memory" error during hand routing or I say at the start of attempting to hand route. I cannot hand route at all. It will auto route.
    Bob Moreno
    Bob Moreno
    http://www.element14.com/community/message/75827#75827
    Hi Bob,
    Could you provide more details about your OS setup? Is this a 64-bit
    machine? Do you have any special type of setup or IT limitations?
    Any and all details are welcome.
    Best Regards,
    Jorge Garcia
