EAGLE User Support (English) Silk & Stop Mask
  • Subscribers 189 subscribers
  • Views 644 views
Silk & Stop Mask
guyd2
guyd2 over 13 years ago
Hi all,
First post here.
I've just designed my first dual layer, relatively complicated board.
Through-hole, with traces on both Top & Bottom (w/ GND plane on top).
Using Eurocircuits' (BE) Design Rules, I get errors for Stop Masks
conflicting with the tPlace silkscreen.
I wonder if I simply can ignore these, or have to wiggle & wriggle the silk
out of the way (somehow) ?
cheers,
_Guy
  • dukepro
    dukepro over 13 years ago in reply to guyd2
    On 05/21/2013 10:27 AM, Guy Drieghe-D. wrote:
    Chuck Huber wrote on Tue, 21 May 2013 16:04
    To reduce the DRC errors, all you have to do is turn the mask layers
    off
    before running the DRC.
    HTH,
        - Chuck
    Hi Chuck, thanks for the swift answer.
    Components are already smashed, but there's not much room to move the
    silkscreen printings (mostly values). It's a very dense board...
    I'm not sure if I understand your note about the DRC-error reducing.
    I placed the silkscreen markings with mask layers off, and indeed didn't
    get errors. Makes sense.
    It's just the Stop Mask layer which throws up errors, but I reckon I need
    to take it into account for fabrication, so, turning them off is kinda
    cheating myself, isn't it ?
    Well... yeah... sort of.
    I'm suggesting that you turn the mask layer on to place the reference
    designator in such a position that it does not overlap the mask
    elements.  However, Many of the components in the library have elements
    on the xPlace layer that WILL overlap the mask.  If you did a DRC with
    the mask layer displayed, it would generate prolific errors regarding
    these overlaps.  The sheer number will tend to obfuscate the mask errors
    to which you want to pay attention, specifically those generated by
    xName overlaps.
    What I generally do is to turn all layers off except Dimension, Pads,
    Vias, xName, xPlace, and xStop.  With this display configuration it's
    easy to place the reference designators so that drills and masks won't
    chop them up.
    Granted, your silk screen will include the xPlace layer (component
    outline, pin 1 desginator, etc).  But you can approve these errors since
    the board house will remove any silk screen over mask areas.  Having
    these chopped up by the board house is not as critical to the finish of
    the board.
    HTH,
        - Chuck
    7026.att1.html.zip
  • guyd2
    guyd2 over 13 years ago in reply to dukepro
    the silk
    Most board houses will mask the silk screen layer off of the solder
    mask
    so that nothing gets on the bare copper.  It's not a fatal error to
    the
    board house, but it will lead to portions of silkscreen lettering
    being
    absent.
    Your best bet is to display the stop layer and smash the components to
    move the reference designator off of the mask.  I generally give it
    about .005 in clearance since the precision of the mask is less
    stringent than other layers, like copper and drills.
    off
    HTH,
        - Chuck
    cheers,
    _g
  • dukepro
    Most board houses will mask the silk screen layer off of the solder mask
    so that nothing gets on the bare copper.  It's not a fatal error to the
    board house, but it will lead to portions of silkscreen lettering being
    absent.
    To reduce the DRC errors, all you have to do is turn the mask layers off
    HTH,
        - Chuck
