EAGLE User Support (English) Exporting PCB.brd file to use on LPKP Milling Machine
  • Subscribers 179 subscribers
  • Views 532 views
Hi All,
I have created a board file from a schematic, following various turorials on the Eagle website and also online.
I am now at a stage where I want to make a board using a LPKF milling machine.  I need to export the board files so they can be used with CircuitCam 6.1 and from there I should be ok as used the LPKF machine with Orcad already.
Does anyone know the proceedure for this as never exported board files from Eagle before, so unsure of the proceedure?
Cheers,
Ant
    With cadence HDL schematic diagram, packaged generated. BRD file without error, opened by pcb editor. BRD file what also have no, what is the problem?
    Former Member over 12 years ago in reply to Former Member
    I don't have cadence presume the .brd file extension is associated with that.  Basically I have a board file in Eagle generated from a schematic in Eagle, and wondering what the next steps are to generating a files/s that can be used by CircuitCam6.1 and then onto BoardMaster for the LPKF machine.
    Is there a guide or somewhere I can look for this information?
    Ant
    autodeskguest over 12 years ago
    On 6/09/2013 12:30 a.m., Ant Scranney wrote:
    Hi All,
    with Orcad already.
    Cheers,
    Ant
    http://www.element14.com/community/message/88363#88363
    Hi
    Read the manual (in the doc folder of your eagle installation). There is
    a section entitled
    "Prototype Manufacture With a Milling Machine"
    HTH
    Warren
    Warren
    If you have any questions about this issue, I suggest you test the online   http://pcb.hqew.net/?s=544864, I used it , a web site is much better. I will online after uploading files, if problem, each other will point out to you
