EAGLE User Support (English) Re: Ratsnest wont' refresh
  • Replies 18 replies
  • Views 3434 views
scott216
scott216 over 12 years ago
Here's a screenshot (link to Flickr) showing the airwires.  Clicking on the
ratsnest button does nothing
http://www.flickr.com/photos/37101040@N00/10279422335/
  • scott216
    scott216 over 12 years ago in reply to dougw
    I tried adding a component and connected it to stuff in the schematic.
    Eagle created new airwires for the new component and when I clicked on the
    ratsnest button, it would update the airwires for the now component, but no
    other airwires would change.  I'm only having this problem with this one
    project.  My other Eagle projects are fine and don't exhibit this problem.
    dougw over 12 years ago in reply to scott216
    Do Ripup and Ratnest still work on new connections if you add a few? Is it just this layout that doesn't work? Or has Eagle just stopped working properly on all layouts?
    Doug
  • scott216
    That didn't help
    Perhaps the traces are not completely ripped up. If you use the Ripup tool and repeatedly click on a specific wire it should rip up the entire trace.
    Doug
  • scott216
    It's a wire.  The ratsnest and autorouter were working fine for this PCB, then all of a sudden this problem cropped up.  I zipped up the files and attached them to the original post.
    It probably means the lines are not "wires", which means they were not drawn on a copper layer.
    You can determine if a line is a wire using the info "i" tool. Simply click on the "i" tool icon and then click or double click on the object or line you want information about. Copper layer objects will show up as a wire in the info box.
    To operate on a group of objects surround them with the box group tool (this will highlight the selection) then click on the operator tool you want to use such as "Ripup", then right click on one of the highlighted objects.
    Doug
  • scott216
    I tried ripup, but it didn't help.  In the command bar I entered: ripup *;
    Hi Scott,
    It looks like the connections are drawn as traces on the PCB layout top copper layer. These can be altered with the "Ripup" tool, which will convert traces back to unrouted nets. If the nets go nowhere, this action will make the trace dissappear.
    Ratsnest will only clean up unrouted nets.
    The connections need to be made on the "Nets" layer in the schematic. Then they will show up as unrouted connections on the PCB layout.
    It is possible to draw connections only on the layout, but if the are not already on the schematic, Eagle does not know where they are supposed to be connected, so you would have to make sure the connections are correct just by your own inspection and editing.
    Doug
