EAGLE User Support (English) Re: Ratsnest wont' refresh
  • Replies 18 replies
  • Views 3435 views
scott216
scott216 over 12 years ago
Here's a screenshot (link to Flickr) showing the airwires.  Clicking on the
ratsnest button does nothing
http://www.flickr.com/photos/37101040@N00/10279422335/
    autodeskguest over 12 years ago in reply to scott216
    Am 17.10.2013 17:04, schrieb scott216:
    I did try copying the schematic to a new file and receating the board
    from scratch, and that worked out fine.  But I was hoping to figure out
    what is wrong with this file in case this happens again to a board I've
    put a significant amount of time in and don't want to start all over.
    http://www.element14.com/community/message/91782#91782
    After the long thread I wanted to give you a fast solution image
    I still have your original and ( or somebody else) may look into it if I
    have time...
    Joern Paschedag
  • scott216
    scott216 over 12 years ago in reply to autodeskguest
    I did try copying the schematic to a new file and receating the board from scratch, and that worked out fine.  But I was hoping to figure out what is wrong with this file in case this happens again to a board I've put a significant amount of time in and don't want to start all over.
    autodeskguest over 12 years ago in reply to dougw
    Am 16.10.2013 16:00, schrieb Douglas Wong:
    Sorry, I can't read the files. I guess my version of Eagle is too old.
    At some point I will have to cough up the money to upgrade.
    I have not seen this but perhaps the connections are not seen because
    they are somehow off grid. Maybe setting the grid to "Finest" will allow
    the program to find the airwires? You can bring components back on grid
    by holding the CTRL key down while selecting a component to move.
    Doug
    http://www.element14.com/community/message/91662#91662
    I did not go into it further....
    I threw away the board and generated a new one from schematics and got
    air wires and ratsnest works...
    Joern Paschedag
    dougw over 12 years ago in reply to scott216
    Sorry, I can't read the files. I guess my version of Eagle is too old. At some point I will have to cough up the money to upgrade.
    I have not seen this but perhaps the connections are not seen because they are somehow off grid. Maybe setting the grid to "Finest" will allow the program to find the airwires? You can bring components back on grid by holding the CTRL key down while selecting a component to move.
    Doug
  • scott216
    scott216 over 12 years ago in reply to dougw
    I uploaded the zip file to the original post on Eagle's forum, but I don't see the original post here on Elemen14.  Anyway, the file is attached to this post.
    CenterPCB.zip
    I am not sure where to get the file - I only see your Flickr picture.
    Doug
  • scott216
    If I manually route a trace, then rip it up, the airwire returns to normal, it doesn't stay where the trace was, it behaves as it should.  Have you tried opening the file and seen this for yourself?  I'm curious if this file would behave the same way on another system.
    Well that is starting to narrow it down.
    If you manually route, can you move the routed traces around?
    Can you ripup one of these manually routed problem traces?
    If you rip it up a moved trace does the airwire stay where the routed trace was or go back to the original problem path?
    Doug
  • scott216
    I can't move an airwire.  If I move an component, the air wire will follow it. or at least the last segment of the air wire.
    Tyring to delete gives me an error saying I should do it in the schemaitc
    I can manually route.
    Autoroute just keeps trying and trying to route.  I don't know when it will give up.  It should take about 15 seconds to route.
    If you manually try moving the problem air wires around does it work?
    If you try to delete one of the problem air wires, does it indicate you must make this edit on the schematic?
    If you try to manually route one of the problem air wires, does it work?
    What happens if you tell it to autoroute the card?
    Doug
