EAGLE User Support (English) Why no single key shortcuts?
  • Replies 7 replies
  • Subscribers 189 subscribers
  • Views 1109 views
autodeskguest over 12 years ago
If Eagle were to require the user to click within the command box before
entering command line text (instead of the command line always being "hot")
that would free up the use of SINGLE key keyboard shortcuts.
As is, having to use one or more modifiers (ie ALT, CTL, SHIFT) means that
after the user has programmed the more easily remembered / easily reached
shortcuts, he soon has to start using more difficult key combinations -or
else do without having a full complement of shortcuts for all available
commands. (sigh)
I have to make a choice between having keyboard chortcuts for various grid
and width (etc.) settings, or command shortcuts. There just aren't enough
easily fingered keyboard combinations available to cover all bases.
I know it would require a lot of coding, but the Options Assign feature of
Eagle could be much more powerful.
  • rachaelp
    rachaelp over 8 years ago in reply to autodeskguest
    Most of us that use EAGLE a lot probably have a pretty streamlined workflow which relies heavily on the command line, and there is always resistance to people who want to change things in a way which breaks peoples workflow. That said, I think your suggestion is quite sensible and allows both methods of working to co-exist. Now, this thread is from 2013 so it's 4 years old and EAGLE has changed ownership from Farnell to Autodesk and they are adding features at a crazy rate so you never know what might happen!
    Best Regards,
    Rachael
    autodeskguest over 8 years ago
    This is silly. The original poster has perfectly legitimate reasons to not want the command prompt always in focus. You do realize that Eagle is a mouse heavy application? Or am I using it incorrectly? Taking my hand off the mouse is the same side of the coin, I still have to change my hands to type in a command. Do what chrome has done, use a keyboard shortcut to bring the command line into focus. Make it a simple Function key. Then let those of us with the creative clicking and dragging to keep our one hand on the mouse and the other able to do single key shortcuts.
    The ergonomics of this application really hasn't been streamlined and I think my suggestion is a compromise between those of us desiring single key shortcuts and those still wanting quick access to the commands.
    https://www.element14.com/community/message/231572
    autodeskguest over 12 years ago in reply to dukepro
    Am 25.11.2013 13:58, schrieb Chuck Huber:
    Olin is absolutely correct here.  Bad idea.
    Yes. Quite bad for the 'power user': Having to click completely defeats
    the idea of the command line (which I use OFTEN).
    If you must do something as drastic as this, at least give me a
    parameter setting that I can put in ~/.eaglerc to revert to the current
    behavior.
    Yes. Either leave the command line unaltered as is, or at least
    implement the possibility to make it behave unaltered via an option.
    Andreas Weidner
    On 11/25/2013 07:58 AM, Chuck Huber wrote:
    On 11/24/2013 11:55 PM, Reece R. Pollack wrote:
    I agree with Olin, but for different reasons.
    I use some applications that have single-key shortcuts, like Mozilla
    Thunderbird. If I accidentally get my focus in the wrong window, any
    typing causes seemingly random and often catastrophic results that are
    very hard to undo, like marking all my unread messages as read, or
    archiving messages.
    This has happened to me numerous times.
    It took me quite some time to find a plug-in that
    would allow me to disable all of the single-key shortcuts and put an end
    to the madness.
    Drifting off-topic a bit, what was the name of this plugin?
    It's called "keyconfig". Here's a link to a blog entry (not mine) that
    describes it:
    http://kb.mozillazine.org/Keyconfig_extension
    Once it's installed you can go to the Add-ons Manager, click
    Preferences, and you'll get a pop-up that lists all the possible actions
    and the currently configured shortcut key. It's a bit laborious to
    disable those you don't want, but you only have to do it once. Just make
    sure you don't blindly disable those you probably want to keep, like
    CTRLC for Cut, CTRLV for Paste, etc.
  • dukepro
    dukepro over 12 years ago in reply to autodeskguest
    On 11/24/2013 03:37 PM, Olin Lathrop wrote:
    Brett Holden wrote on Sun, 24 November 2013 14:20
    before
    No, no, no.  Absolutely not!!!
    There are plenty of single keys and one-modifier keys for quick
    functions.  The more rarely used functions can be typed quicker than
    mouse clicking your way through pull-down menus.
    Time this as an example:  Change the width of multiple traces to a
    common value, say, 32 mils.  Try it with the click-right context menu,
    then again with the Change pull-down menu, then finally with text.  With
    text it's "ch wid 32".
    behavior.
    archiving messages.
    to the madness.
        - Chuck
    autodeskguest over 12 years ago in reply to autodeskguest
    before
    archiving messages. It took me quite some time to find a plug-in that
    to the madness.
    before
    One of the important features of a command line is that it is quicker and
    easier to type a command than to have to use the mouse and click something.
    Having to use the mouse to enable the command line makes no sense as it
    would completely defeat this.
    Also, there are already plenty of keyboard shortcuts.  F1-F12 give you 12
    single-key shortcuts.  Then there are many more that require only a single
    modifier key, like CTRL or ALT for the alphabetic keys and CTRL, ALT, and
    SHIFT for the F-keys.  That already totals 100 single or single-modifier
    shortcuts.  There is no problem to solve here.
