EAGLE User Support (English) Shaping a Ground plane
  • Subscribers 187 subscribers
  • Views 607 views
I want to shape the ground plane and remove the unnecessary parts of the ground plane and make everything tidy. Its manually routed on bottom layer so that I can easily make it using toner transfer method at home. So far I used bRestrict and drew polygons to remove parts of the ground plane that are unncessary. But it is not even. For example. See the bottom left corner of the board below. I want the ground plane to be perfect.
It's my second PCB Im routing myself. So I am open to suggestions. It is a USBASP circuit to program Atmel Atmega MCUs
    autodeskguest over 12 years ago
    Use more then one ground polygon.They will be smaller then the board.
    Use the split and miter to move the edge of the polygon to clear the
    areas as needed. Instead of restrict polygons just use a thin wire. Be
    sure to have orphans off on the polygon.
    This is an example with the +5 buss highlighted and down mostly with
    polygons
    http://arcelectronicsinc.com/testinfo/plus5.png
    Paul
