EAGLE User Support (English) Need trace stretch feature
  • Subscribers 190 subscribers
  • Views 1037 views
  • eagle
  • cad
  • stretch
Would it be possible to add a trace stretch feature that preserves adjacent segment angles?  This feature would really be helpful when routing more complex designs.  Being able to do this for multiple selected traces would be nice, but just preserving adjacent angles for a single trace when moving would be a huge improvement.  Our usual layout engineer refuses to use Eagle on complex boards (high-density BGA) only because of this lacking feature.  Now that I'm forced to route this board,  I see why.  It would be very helpful.
Description from another software of the feature needed:
Track Dragging with Angle Preservation
Re-routing is not always the best approach to modifying routing, for example, situations where you want to move a track segment slightly, keeping the neat 45° and 90° corners at either end. (xxxxxx)  supports this, through multi-track dragging with angle preservation. Dragging behavior is controlled by the Preserve Angle When Dragging option in the PCB Editor - Interactive Routing page of the Preferences dialog.
To drag, click once on the segment to select it - the cursor will change to a quad-arrow - then click and drag to slide it to a new location. You will notice that the angles to adjacent track segments are preserved, maintaining the routing style.
  • e14candies
    e14candies over 10 years ago in reply to e14 Contributor
    I wouldn't say so.  We probably still don't have a native bottom board view
    either.
    Don't try to wake them.
    e14 Contributor over 10 years ago in reply to autodeskguest
    Has this feature been implemented yet in Eagle v7.6?
    This, without a doubt, would have to be my #1 feature request!!!
    autodeskguest over 12 years ago in reply to e14 Contributor
    rf1 wrote on Mon, 02 June 2014 11:14
    If eagle is already capable of preserving angles for adjacent angles
    using a ctrl-g / alt-g group mapping,  is there some documentation on
    how this works?   If you mean selecting the segment and adjacent
    segments in a group, then moving that, then I understand.  That is
    not
    what I'm suggesting though.
    It would be a very helpful option to have the length of the segments
    change when moving a trace while preserving the adjacent angles
    instead of having the selected segment stay the same length while the
    angles are adjusted (how eagle currently works).  Hope that makes
    sense.
    I understand what you are asking.  I just offered an option to help with
    the current state of EAGLE.  Using the group command can help you move a
    group of traces while maintaining the angles of the selected wire segments.
    It isn't the full solution but it could help you be more efficient in the
    short term.
    Long term, I agree it should work better and I'd like to see what you have
    suggested.
    Cheers,
    James.
    Specializing in CadSoft EAGLE
    • Electronic Design Services
    Take advantage of v7 License Promotion right now at
    http://www.eaglecentral.ca
    If eagle is already capable of preserving angles for adjacent angles using a ctrl-g / alt-g group mapping,  is there some documentation on how this works?   If you mean selecting the segment and adjacent segments in a group, then moving that, then I understand.  That is not what I'm suggesting though.
    It would be a very helpful option to have the length of the segments change when moving a trace while preserving the adjacent angles instead of having the selected segment stay the same length while the angles are adjusted (how eagle currently works).  Hope that makes sense.
  • kikoun
    kikoun over 12 years ago in reply to autodeskguest
    Right now with EAGLE v6, to get what you are looking for, it can be done
    but you have to first group the segments you want.  I have group assigned
    to CTRL+G so it is pretty quick but it does take more mouse clicks.  And on
    dense designs (of which we've done many) it would be much more efficient if
    these angles were maintained during moving so that grouping was not
    required for most basic moves.
    I use that technique too (except that I assign ALT+G instead of Ctrl+G ! ). But this is efficient when we move several wires. When moving a single wire it's quite annoying.
    I would point out that if this feature could be add to eagle, it would be nice to implement it for every 'wire style' element such as polygons borders.
    And of course, it can also be useful in schematic and library editor...
    Guillaume.
    Todd Elliott wrote on Wed, 28 May 2014 13:09
    a
    layout
    only
    h2. Track Dragging with Angle Preservation
    supports
    dialog.
    change
    You
    Hello Todd,
    I know you didn't mention it, but taking the first sentence and googling
    it, I can see that you've taken that text from Altium's docs.  But let's
    not give the excuse of an expensive tool having this feature.  KiCAD (the
    gEDA open-source CAD tool) now has something very similar thanks to the
    good folks at CERN.  See this tutorial:
    ( reference https://www.youtube.com/watch?v=CCG4daPvuVI )
    So it appears that the low bar of the industry has just been raised.  This
    is a good time for such a feature to be added to EAGLE.  I'm not asking for
    all this interactive routing to be added right away, but being able to move
    a trace and keep the angles of adjacent segments would be useful.  I also
    like their snapping feature when one segment lines up with another and it
    can be optimised into one line--that is a nice touch.
    Cheers,
    James.
