EAGLE User Support (English) same name to more pins in a custom library
  • Subscribers 189 subscribers
  • Views 2987 views
hi, as the title says, how can I give the same name to multiple pins of an ic in a custom library? when i try i have the error that the name already exists.
thanks
  • ootbrobo
    ootbrobo over 12 years ago
    Another great option is  to join multiple package pads to a single symbol pin. Note EAGLE this feature was only introduced in version 6.
    Notice how pads 8 18 30 38 and 45 are all connected to the symbol GND.  When connecting package pads and symbol pins you can select multiple pads using shift (or ctrl I think).  You can also select existing connections and "APPEND" additional pads.  To each's own.
    And here is the end result.  You get a schematic symbol that has no redundant pins, which makes for cleaner, and more robust designs.
    e14 Contributor over 12 years ago in reply to Richard_H
    ok, thanks
  • Richard_H
    Richard_H over 12 years ago
    you could name the pins for example
    name@1, name@2, name@3 and so on. EAGLE will show the name (before the @) in the schematic only. So it looks like identical names.
    HTH
    Richard
