EAGLE User Support (English) initial automatic component placement grid is wrong/how to change it
  • Replies 12 replies
  • Subscribers 187 subscribers
  • Views 2499 views
I'm using Eagle Pro 6.6.
I noticed a behaviour that has me very frustrated and I can't find a way
to fix it.
If I create a Schematic with say 64 LED's (SMD devices to created with a
grid on 0.1mm in the library)
And wire them up appropriately in the schematic.
then switch to the PCB view, the 64 LED's are automatically placed on
the board outside of the default PCB area, but they are placed in a n
array  pattern that i have no control over, and that seems to be
slightly off when I then set the PB grid to 0.1mm for placement...
from row to row of LED's they are slightly misaligned when i pick them
up to place them they don't line up correctly with LED's that were
dropped in the array on the line above, or to the right...
So I am having a devil of a job laying out my final array or LED's
according to an exact alignment as the components are off some fraction
of my grid that I can't adjust for (even with the fine grid set very
fine), and anyway that is now extremely time consuming (imaging 1000
LED's that all need to be manually aligned rather than snapping to an
exact grid.
Is there a fix for this initial automatic grid when initially creating a
PCB to work on ?
Any help or ULP's to fix this would be appreciated...
I even took a look at editing the .brd XML file and while is looks
possible it is too daunting of a task and possibly more manual and
probably error prone.
    autodeskguest over 11 years ago in reply to autodeskguest
    On 02/09/14 00:24, peter wrote:
    Warren, thank you, that helps a lot and you didn't get a bit snarky like
    Olin image
    Olin does get snarky on occasion, but usually only with people who are
    so pig-headedly focussed on their original, wrong approach that they
    flatly refuse to even contemplate the three better methods (and one
    simple 'fix') they've already been offered. I can sympathise with his
    frustration sometimes.
    to fix it.
    exact grid.
    PCB to work on ?
    When you create a board from a schematic the board is created with the
    default grid and the packages are initially on that grid. Then if you
    change the grid to what you want, the packages don't adjust their
    position so they are 'off grid' at that time.
    There is a ULP you could run before you start to layout which will move
    all your packages onto your nominated grid. Have a look at cmd-snap-brd.ulp
    HTH
    Warren
    Olin image
    peter wrote on Mon, 01 September 2014 05:05
    Normally you wouldn't even have the sea of unplaced parts in view
    when
    doing placement.  All that matters is that they are out there
    somewhere.
    As you walk thru the schematic (I print it out, then cross off
    parts as I
    place them) to place parts on the board, you enter the part name
    and it
    shows up at the cursor.  Wherever it was previous to that is
    completely
    irrelevant.
    I have not delved into writing ULPs yet... one day when i have time.
    Huh?  What does anything I mentioned there have to do with ULPs?  Read what
    I wrote.  This is just using Eagle commands normally.
    peter wrote on Mon, 01 September 2014 04:56
    It is difficult to explain
    Actually it's quite clear what Eagle is doing.  The part that makes no
    sense is why this should be a problem.
    Quote:
    build a simple schematic with say 40 SMD LED's (use an LED designed on
    a mm based grid) and then move to a board to start laying the PCB..  now
    if you have a default eagle.scr file it will have placed those components
    in a board with a default 0.1" grid and will have dropped
    them in an array (based on that 0.1" grid) to the side of the board...
    OK
    Quote:
    now if you change the grid to the mm grid that is best for the LED's
    you will note that as you try to pick up and place them in a mm based
    grid, the LED's from the first row will not align perfectly with the
    LED's
    This is what makes no sense for at least three obvious reasons.
    First, by "pick up" it seems you are trying to drag the parts onto the
    board individually.  Clearly you want to make a script to place a array of
    40 parts.
    Second, even for individual parts, dragging them from off the board doesn't
    make sense.  It is slow and tedius because it requires more mouse usage,
    you have to zoom back to see the board and the whole off-board holding area
    for the parts, and it can be quite difficult to find a small part in the
    holding area.  With the MOVE command, you can keep the view zoomed into the
    small area of the board you are currently working on, you enter the
    designator directly without having to hunt for the part, and the original
    grid doesn't matter.  The part just appears at the cursor from "someplace".
    You don't need to know nor care where that someplace is.  Since this is
    done a lot during placement, I have F12 set up for 'ratsnest; move'.  Note
    no semicolon after MOVE.  That doesn't end the command so that I can type
    the part designator parameter.  To place a part, I hit F12 type the
    designator, and hit ENTER.  Poof, the part appears at the cursor much
    faster than someone go over to the part holding area hunt around for it and
    drag it back to where they're working, probably requiring some more panning
    and zooming.
    Third, even if you want to do it the slow and tedius way, CTRL lets you
    pick up the part at its origin regardless how it might be snapped to the
    grid.  Didn't you read the help on MOVE at all!!?
    You should at least learn the tool before complaining about it.
    On 08/31/2014 04:48 AM, Olin Lathrop wrote:
    peter wrote on Sat, 30 August 2014 18:54
    a PCB to work on ?
    By mentioning "fix", you imply there is anything wrong with how it works
    now.  There isn't.  There is no reason to care where exactly unplaced part
    are initially put off-board, since they are, well, unplaced.
    yes and no. yes they are 'unplaced' but they are unplaced according to a
    grid that is derived from the defaults set up in the eagle.scr file.
    once they have been 'unplaced' they are tied to a position relative to
    the grid (initially they are on a 0.1" grid), but if I change to a 1mm
    grid they now obtain a new relative position according to their current
    position off the 1mm grid, and when moved they will maintain that offset
    from the 1mm grid, getting them back onto the 1mm grid is what I'm
    struggling with.
    Normally you wouldn't even have the sea of unplaced parts in view when
    doing placement.  All that matters is that they are out there somewhere.
    As you walk thru the schematic (I print it out, then cross off parts as I
    place them) to place parts on the board, you enter the part name and it
    shows up at the cursor.  Wherever it was previous to that is completely
    irrelevant.
    However, when you have a regular array of parts to place, you wouldn't do
    this manually anyway.  That would be too slow, tedius, and unreliable.
    Write a program that generates the script to place the array of parts, then
    run the script.  The original positions of all the placed parts is
    irrelevant.  If there is a error in the script or you want to change
    something, you regenerate and rerun the script.  The parts will show up in
    their new positions, this time even though they were previously placed on
    the board.  Again, the previous positions of the parts doesn't matter.
    There is no problem here, so nothing to fix.
    On 08/30/2014 10:45 PM, Joern Paschedag wrote:
    Am 31.08.2014 um 01:21 schrieb peter:
    to fix it.
    exact grid.
    PCB to work on ?
    To clarify, the schematic is drawn with the standard 0.1" grid, but when
    creating the board a default 0.05" grid is used to drop all of my
    componenets onto in an array to the side of the default PCB area, but
    row to row and column to column placements are off once the placement
    grid is set to my 1mm grid by fractions of a mm but its enoght o make
    final placement of the components impossible without setting a
    ridiculously fine alternate grid setting.
    there must be a way to make eagle default to a metric grid on the PCB
    layer before it has already dropped all my components on there for me to
    then place.
    AARGH..
    Well inch is not millimetres image
    So if you use devices with fractions of millimetres spacing why don't
    you set the grid appropriate? You can set it to microns, mils, inch and
    millimetres and if you want a default setting you can do that in the
    eagle.scr file.
    Help grid.
    It is difficult to explain .. but try it and you'll see... build a
    simple schematic with say 40 SMD LED's (use an LED designed on a mm
    now if you have a default eagle.scr file it will have placed those
    components in a board with a default 0.1" grid and will have dropped
    now if you change the grid to the mm grid that is best for the LED's you
    will note that as you try to pick up and place them in a mm based grid,
    the LED's from the first row will not align perfectly with the LED's
    from the second row, or the third row... etc... even with very very fine
    alternate grid spacing its all but impossible to  get them to align
    perfectly (and this defeats the purpose of having a grid anyway, since
    that is supposed to help with rapid aligned placement of devices)
    to fix it.
    exact grid.
    PCB to work on ?
    HTH
    Warren
    a PCB to work on ?
    irrelevant.
    then place.
    AARGH..
    As Doug said, the initial placement of parts on the blank board is
    merely a holding area. They're just dumped there with no attempt to
    psychically second-guess your actual desires. The use of a 0.05" grid is
    the default and makes a lot of sense because even these days most
    components are actually built to an imperial grid.
    When moving the LEDs to where you want them, you will need to place them
    on your preferred grid. Press the  key when you pick them up to
    move them. This does a "snap-to-grid" using the grid you currently have set.
    Alternatively, place them using the command line, where precise
    coordinates can be entered. Or write a script to do so, or a ULP (or
    Python program or whatever) to auto-generate said script.
    HTH
    Rob
    to fix it.
    exact grid.
    PCB to work on ?
    then place.
    AARGH..
    eagle.scr file.
    Help grid.
    Joern Paschedag
