EAGLE User Support (English) CONSTANT crashing Eagle 7.1.0 under MacOS 10.9.4 - is Eagle a real piece of software?
  • Replies 10 replies
  • Subscribers 189 subscribers
  • Views 1331 views
I have an urgent project that *constantly* crashed the autorouter approximately 95% of the time.  The result is an application that is utterly unusable, and while tweaking the auto router and doing things like routing the ground plane first eventually produced a 100% route, the polygons subsequently "fall apart" on my ground plane, completing only 80% of the only fairly complex board.
System has 24 cores at 3.46Ghz and 64GB of ram...
Is this software just junk?
    e14 Contributor over 10 years ago in reply to e14 Contributor
    Just checked the new beta 7.5.4 - the same problem
    e14 Contributor over 10 years ago in reply to autodeskguest
    Hi there,
    I have the same problem - random crashes every 5-50 min.
    Eagle 7.5.0, Mac OS 10.9.5.  I really doubt it is related to the memory - I've got 18Gb and no other apps are running.
    If I run an old version 6.6.0 - no problems besides the commonly known screen re-draw issue.
    Cheers
    Kir
    autodeskguest over 10 years ago in reply to e14 Contributor
    Am 24.04.2016 um 04:01 schrieb Herb Sims:
    Jorge,
    I am having the same problem with V7.5 and Mac El Capitan OS.
    Here is what is says after more more than 30 seconds of autorouter:
    | Process:            | EAGLE |
    | Path:               |
    /Applications/EAGLE-7.5.0/EAGLE.app/Contents/MacOS/EAGLE |
    | Identifier:         | EAGLE |
    | Version:            | 7.5.0 (7.5.0) |
    | Code Type:          | X86-64 (Native) |
    | Parent Process:     | ??? |
    | Responsible:        | EAGLE |
    | User ID:            | 501 |
    Could be a memory problem. What are the grid settings for the
    Autorouter and the size of the board? How many routing jobs are
    running simultaniously?
    Richard Hammerl
    Jorge,
    | Process:            | EAGLE |
    | Path:               |
    | User ID:            | 501 |
    Richard Hammerl
    Jorge,
    | Process:            | EAGLE |
    | Path:               |
    | User ID:            | 501 |
    Richard Hammerl
  • clem57
    clem57 over 10 years ago in reply to e14 Contributor
    This can be a sign that you ran out of memory. If you are running other processes, please stop them and try again.
    Jorge,
    Process:           EAGLE [2268]
    Path:              /Applications/EAGLE-7.5.0/EAGLE.app/Contents/MacOS/EAGLE
    Identifier:        EAGLE
    Version:           7.5.0 (7.5.0)
    Code Type:         X86-64 (Native)
    Parent Process:    ??? [1]
    Responsible:       EAGLE [2268]
    User ID:           501
    Date/Time:         2016-04-23 21:00:43.337 -0500
    OS Version:        Mac OS X 10.11.4 (15E65)
    Report Version:    11
    Anonymous UUID:    FAA64798-33F7-1333-20D5-274F24BBC542
    Sleep/Wake UUID:   2EF7F387-F386-4783-A9E7-3862F4B53CC6
    Time Awake Since Boot: 34000 seconds
    Time Since Wake:   520 seconds
    System Integrity Protection: enabled
    Crashed Thread:    10  Thread (pooled)
    Exception Type:    EXC_BAD_ACCESS (SIGBUS)
    Exception Codes:   KERN_PROTECTION_FAILURE at 0x0000700000531ff8
    Exception Note:    EXC_CORPSE_NOTIFY
    VM Regions Near 0x700000531ff8:
    Stack              00007000004af000-0000700000531000 [  520K] rw-/rwx SM=COW  thread 9
    --> STACK GUARD        0000700000531000-0000700000532000 [4K] ---/rwx SM=NUL  stack guard for thread 10
    Stack              0000700000532000-00007000005b4000 [  520K] rw-/rwx SM=COW  thread 10
    Thread 0:: Dispatch queue: com.apple.main-thread
    0   libsystem_kernel.dylib   0x00007fff88c3ef72 mach_msg_trap + 10
    1   libsystem_kernel.dylib   0x00007fff88c3e3b3 mach_msg + 55
    2   com.apple.CoreFoundation 0x00007fff93ec01c4 __CFRunLoopServiceMachPort + 212
    3   com.apple.CoreFoundation 0x00007fff93ebf68c __CFRunLoopRun + 1356
    4   com.apple.CoreFoundation 0x00007fff93ebeed8 CFRunLoopRunSpecific + 296
    5   com.apple.HIToolbox      0x00007fff98918935 RunCurrentEventLoopInMode + 235
    6   com.apple.HIToolbox      0x00007fff9891876f ReceiveNextEventCommon + 432
    7   com.apple.HIToolbox      0x00007fff989185af _BlockUntilNextEventMatchingListInModeWithFilter + 71
    8   com.apple.AppKit         0x00007fff871a1efa _DPSNextEvent + 1067
    9   com.apple.AppKit         0x00007fff871a132a -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
    10  EAGLE                    0x00000001006d9e25 0x100000000 + 7183909
    11  EAGLE                    0x0000000100ec13bd 0x100000000 + 15471549
    12  EAGLE                    0x0000000100927e30 0x100000000 + 9600560
    13  EAGLE                    0x0000000100523a31 0x100000000 + 5388849
    14  EAGLE                    0x00000001001242a4 0x100000000 + 1196708
    15  EAGLE                    0x0000000100120a79 0x100000000 + 1182329
    16  EAGLE                    0x000000010011fdf4 0x100000000 + 1179124
    17  EAGLE                    0x00000001000d0c2e 0x100000000 + 855086
    18  EAGLE                    0x0000000100556bdd 0x100000000 + 5598173
    19  EAGLE                    0x00000001005559ee 0x100000000 + 5593582
    20  EAGLE                    0x0000000100569792 0x100000000 + 5674898
    21  EAGLE                    0x0000000100edd19b 0x100000000 + 15585691
    22  EAGLE                    0x00000001007caf23 0x100000000 + 8171299
    23  EAGLE                    0x00000001008ab9c2 0x100000000 + 9091522
    24  EAGLE                    0x00000001005dcb28 0x100000000 + 6146856
    25  EAGLE                    0x00000001007973dc 0x100000000 + 7959516
    26  EAGLE                    0x000000010079a5ed 0x100000000 + 7972333
    27  EAGLE                    0x0000000100ec4964 0x100000000 + 15485284
    28  EAGLE                    0x00000001006da69e 0x100000000 + 7186078
    29  EAGLE                    0x00000001006daf61 0x100000000 + 7188321
    30  com.apple.CoreFoundation 0x00007fff93ee0881 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
    31  com.apple.CoreFoundation 0x00007fff93ebffbc __CFRunLoopDoSources0 + 556
    32  com.apple.CoreFoundation 0x00007fff93ebf4df __CFRunLoopRun + 927
    33  com.apple.CoreFoundation 0x00007fff93ebeed8 CFRunLoopRunSpecific + 296
    34  com.apple.HIToolbox      0x00007fff98918935 RunCurrentEventLoopInMode + 235
    35  com.apple.HIToolbox      0x00007fff9891876f ReceiveNextEventCommon + 432
    36  com.apple.HIToolbox      0x00007fff989185af _BlockUntilNextEventMatchingListInModeWithFilter + 71
    37  com.apple.AppKit         0x00007fff871a1efa _DPSNextEvent + 1067
    38  com.apple.AppKit         0x00007fff871a132a -[NSApplication _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 454
    39  com.apple.AppKit         0x00007fff87195e84 -[NSApplication run] + 682
    40  EAGLE                    0x00000001006d9e85 0x100000000 + 7184005
    41  EAGLE                    0x0000000100ec13bd 0x100000000 + 15471549
    42  EAGLE                    0x0000000100ec420a 0x100000000 + 15483402
    43  EAGLE                    0x000000010026cc49 0x100000000 + 2542665
    44  EAGLE                    0x000000010026e523 0x100000000 + 2549027
    45  libdyld.dylib            0x00007fff8c60e5ad start + 1
    Thread 1:
    0   libsystem_kernel.dylib   0x00007fff88c455e2 __workq_kernreturn + 10
    1   libsystem_pthread.dylib  0x00007fff9870d578 _pthread_wqthread + 1283
    2   libsystem_pthread.dylib  0x00007fff9870b341 start_wqthread + 13
    Thread 2:: Dispatch queue: com.apple.libdispatch-manager
    0   libsystem_kernel.dylib   0x00007fff88c45efa kevent_qos + 10
    1   libdispatch.dylib        0x00007fff87e27165 _dispatch_mgr_invoke + 216
    2   libdispatch.dylib        0x00007fff87e26dcd _dispatch_mgr_thread + 52
    Thread 3:
    Thread 4:
    Thread 5:
    Thread 6:
    Thread 7:
    Thread 8:: com.apple.NSEventThread
    5   com.apple.AppKit         0x00007fff872f7e99 _NSEventThread + 149
    6   libsystem_pthread.dylib  0x00007fff9870d99d _pthread_body + 131
    7   libsystem_pthread.dylib  0x00007fff9870d91a _pthread_start + 168
    8   libsystem_pthread.dylib  0x00007fff9870b351 thread_start + 13
    Thread 9:
    Thread 10 Crashed:: Thread (pooled)
    0   EAGLE                    0x000000010003e068 0x100000000 + 254056
    1   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    2   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    3   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    4   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    5   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    6   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    7   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    8   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    9   EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    10  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    11  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    12  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    13  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    14  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    15  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    16  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    17  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    18  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    19  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    20  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    21  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    22  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    23  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    24  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    25  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    26  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    27  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    28  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    29  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    30  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    31  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    32  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    33  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    34  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    35  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    36  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    37  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    38  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    39  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    40  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    41  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    42  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    43  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    44  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    45  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    46  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    47  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    48  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    49  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    50  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    51  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    52  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    53  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    54  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    55  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    56  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    57  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    58  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    59  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    60  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    61  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    62  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    63  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    64  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    65  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    66  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    67  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    68  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    69  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    70  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    71  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    72  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    73  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    74  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    75  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    76  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    77  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    78  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    79  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    80  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    81  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    82  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    83  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    84  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    85  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    86  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    87  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    88  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    89  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    90  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    91  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    92  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    93  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    94  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    95  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    96  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    97  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    98  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    99  EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    100 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    101 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    102 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    103 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    104 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    105 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    106 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    107 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    108 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    109 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    110 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    111 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    112 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    113 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    114 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    115 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    116 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    117 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    118 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    119 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    120 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    121 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    122 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    123 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    124 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    125 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    126 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    127 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    128 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    129 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    130 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    131 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    132 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    133 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    134 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    135 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    136 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    137 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    138 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    139 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    140 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    141 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    142 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    143 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    144 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    145 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    146 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    147 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    148 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    149 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    150 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    151 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    152 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    153 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    154 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    155 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    156 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    157 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    158 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    159 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    160 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    161 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    162 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    163 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    164 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    165 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    166 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    167 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    168 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    169 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    170 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    171 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    172 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    173 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    174 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    175 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    176 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    177 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    178 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    179 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    180 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    181 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    182 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    183 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    184 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    185 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    186 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    187 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    188 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    189 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    190 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    191 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    192 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    193 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    194 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    195 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    196 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    197 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    198 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    199 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    200 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    201 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    202 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    203 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    204 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    205 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    206 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    207 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    208 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    209 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    210 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    211 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    212 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    213 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    214 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    215 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    216 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    217 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    218 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    219 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    220 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    221 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    222 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    223 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    224 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    225 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    226 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    227 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    228 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    229 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    230 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    231 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    232 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    233 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    234 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    235 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    236 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    237 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    238 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    239 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    240 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    241 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    242 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    243 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    244 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    245 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    246 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    247 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    248 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    249 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    250 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    251 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    252 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    253 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    254 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    255 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    256 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    257 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    258 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    259 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    260 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    261 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    262 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    263 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    264 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    265 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    266 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    267 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    268 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    269 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    270 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    271 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    272 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    273 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    274 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    275 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    276 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    277 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    278 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    279 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    280 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    281 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    282 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    283 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    284 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    285 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    286 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    287 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    288 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    289 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    290 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    291 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    292 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    293 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    294 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    295 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    296 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    297 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    298 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    299 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    300 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    301 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    302 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    303 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    304 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    305 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    306 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    307 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    308 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    309 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    310 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    311 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    312 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    313 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    314 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    315 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    316 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    317 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    318 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    319 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    320 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    321 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    322 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    323 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    324 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    325 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    326 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    327 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    328 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    329 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    330 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    331 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    332 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    333 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    334 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    335 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    336 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    337 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    338 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    339 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    340 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    341 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    342 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    343 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    344 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    345 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    346 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    347 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    348 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    349 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    350 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    351 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    352 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    353 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    354 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    355 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    356 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    357 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    358 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    359 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    360 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    361 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    362 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    363 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    364 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    365 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    366 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    367 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    368 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    369 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    370 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    371 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    372 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    373 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    374 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    375 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    376 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    377 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    378 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    379 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    380 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    381 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    382 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    383 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    384 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    385 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    386 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    387 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    388 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    389 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    390 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    391 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    392 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    393 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    394 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    395 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    396 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    397 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    398 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    399 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    400 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    401 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    402 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    403 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    404 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    405 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    406 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    407 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    408 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    409 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    410 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    411 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    412 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    413 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    414 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    415 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    416 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    417 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    418 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    419 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    420 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    421 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    422 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    423 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    424 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    425 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    426 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    427 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    428 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    429 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    430 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    431 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    432 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    433 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    434 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    435 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    436 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    437 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    438 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    439 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    440 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    441 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    442 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    443 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    444 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    445 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    446 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    447 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    448 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    449 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    450 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    451 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    452 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    453 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    454 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    455 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    456 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    457 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    458 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    459 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    460 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    461 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    462 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    463 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    464 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    465 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    466 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    467 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    468 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    469 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    470 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    471 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    472 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    473 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    474 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    475 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    476 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    477 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    478 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    479 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    480 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    481 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    482 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    483 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    484 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    485 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    486 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    487 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    488 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    489 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    490 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    491 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    492 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    493 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    494 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    495 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    496 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    497 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    498 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    499 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    500 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    501 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    502 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    503 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    504 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    505 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    506 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    507 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    508 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    509 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    510 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    511 EAGLE                    0x000000010003e0b5 0x100000000 + 254133
    Thread 11:: Thread (pooled)
    0   libsystem_kernel.dylib   0x00007fff88c44db6 __psynch_cvwait + 10
    1   libsystem_pthread.dylib  0x00007fff9870e728 _pthread_cond_wait + 767
    2   EAGLE                    0x0000000100d8c580 0x100000000 + 14206336
    3   EAGLE                    0x0000000100d8c3bb 0x100000000 + 14205883
    4   EAGLE                    0x0000000100d8c372 0x100000000 + 14205810
    5   EAGLE                    0x0000000100d880e1 0x100000000 + 14188769
    6   EAGLE                    0x0000000100d8b192 0x100000000 + 14201234
    7   libsystem_pthread.dylib  0x00007fff9870d99d _pthread_body + 131
    8   libsystem_pthread.dylib  0x00007fff9870d91a _pthread_start + 168
    9   libsystem_pthread.dylib  0x00007fff9870b351 thread_start + 13
    Thread 12:: Thread (pooled)
    Thread 13:: Thread (pooled)
    Thread 10 crashed with X86 Thread State (64-bit):
      rax: 0x0000000114125fd0  rbx: 0x0000000114125fe0  rcx: 0x0000000113f16e60  rdx: 0x000000011424c800
      rdi: 0x000000010d403900  rsi: 0x0000000113f16da0  rbp: 0x0000700000532010  rsp: 0x0000700000532000
       r8: 0x0000000112f47690   r9: 0x00000000fffff800  r10: 0x000000000ef99735  r11: 0x000000010de00000
      r12: 0x000000010d403930  r13: 0x004990c00024f580  r14: 0x000000010d403900  r15: 0x0000000113f16e00
      rip: 0x000000010003e068  rfl: 0x0000000000010246  cr2: 0x0000700000531ff8
    Logical CPU: 6
    Error Code:  0x00000006
    Trap Number: 14
    Binary Images:
       0x100000000 -    0x1015bcfef +EAGLE (7.5.0 - 7.5.0) <69ECFDFD-2502-37A1-A8E1-214C70D216B4> /Applications/EAGLE-7.5.0/EAGLE.app/Contents/MacOS/EAGLE
       0x1095fa000 -    0x1095fafe7 +cl_kernels (???) <0DBF9E9D-B6FB-4184-BA4C-4C4E0A43B11F> cl_kernels
       0x10d017000 -    0x10d07dff7  com.apple.driver.AppleIntelHD5000GraphicsMTLDriver (10.14.58 - 10.1.4) <A2BFF9AB-2561-3384-986E-8E3767FE3F68> /System/Library/Extensions/AppleIntelHD5000GraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelHD5000GraphicsMTLDriver
    0x7fff6e9c5000 - 0x7fff6e9fc0d7  dyld (360.21) <D9B236BC-4AC1-325F-B3EF-3F06DBDA7119> /usr/lib/dyld
    0x7fff848f2000 - 0x7fff84d20fff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fff84d21000 - 0x7fff84d71ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fff84ee5000 - 0x7fff84ff4fe7  libvDSP.dylib (563.5) <9AB6CA3C-4F0E-35E6-9184-9DF86E7C3DAD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fff84ff5000 - 0x7fff84ff7ffb  libutil.dylib (43) <4C9BFE8B-563B-3EEA-A323-8F4F14E0A46C> /usr/lib/libutil.dylib
    0x7fff859fe000 - 0x7fff85ce3ffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fff85db9000 - 0x7fff85dd5ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
    0x7fff86096000 - 0x7fff860ebfff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fff86589000 - 0x7fff86589fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
    0x7fff8658a000 - 0x7fff8658fff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
    0x7fff86590000 - 0x7fff86594fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
    0x7fff86681000 - 0x7fff86687fff  com.apple.IOAccelerator (205.3 - 205.3) <851B6BF8-5B7F-3FB5-9E45-10AAE3BF7438> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fff86688000 - 0x7fff866a1fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
    0x7fff868cc000 - 0x7fff8696cfff  com.apple.Metadata (10.7.0 - 972.29.1) <F19E0200-6937-3799-9C67-D26C2CE5AA5F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fff869cd000 - 0x7fff86a42fff  com.apple.framework.IOKit (2.0.2 - 1179.40.20) <FB2AD43B-905D-3BD0-BE17-ACE7D4D13E24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fff86a58000 - 0x7fff86a58fff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fff86a7b000 - 0x7fff86b6affb  libxml2.2.dylib (29.5) <4096C2EA-6659-3F22-AC60-1E2F30BDD2B7> /usr/lib/libxml2.2.dylib
    0x7fff86c1f000 - 0x7fff86c27fff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fff86c95000 - 0x7fff86c95fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fff86c96000 - 0x7fff86c97fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fff86ca2000 - 0x7fff86cd6ff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fff86cd7000 - 0x7fff86ce1fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fff86ce4000 - 0x7fff86ce8fff  libGIF.dylib (1444) <D3F44A33-355E-3154-A465-1C732AAC5F75> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fff86d3c000 - 0x7fff86d52ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fff86de9000 - 0x7fff86e14ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
    0x7fff86e1b000 - 0x7fff86fe9ff3  com.apple.QuartzCore (1.11 - 410.14) <0283748A-8318-36AC-8B30-8A951FEB305A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fff86ff4000 - 0x7fff8709bfff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fff870b7000 - 0x7fff870f5ff7  libGLImage.dylib (12.0.40.6) <734B133F-E789-3A25-9DE6-1CCBA4896D4D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fff87126000 - 0x7fff87132ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fff87159000 - 0x7fff87d82fff  com.apple.AppKit (6.9 - 1404.46) <2492D315-76B6-320B-B542-231FCA44CA48> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fff87dfb000 - 0x7fff87e09ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
    0x7fff87e1f000 - 0x7fff87e4cfff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
    0x7fff880e9000 - 0x7fff880ecfff  libsystem_sandbox.dylib (460.40.33) <30671DCC-265F-325A-B33D-11CD336B3DA3> /usr/lib/system/libsystem_sandbox.dylib
    0x7fff881ee000 - 0x7fff881fffff  libSparseBLAS.dylib (1162.2) <EBEB3848-3468-342A-91A6-5C47F2369CD9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fff88200000 - 0x7fff88212fff  libsasl2.2.dylib (209) <2F81C8C9-11A3-3581-B2C1-D8C03AB7D39C> /usr/lib/libsasl2.2.dylib
    0x7fff8827f000 - 0x7fff88281fff  com.apple.xpc.ServiceManagement (1.0 - 1) <F3E14561-5DF4-3429-98ED-8F27A87A343A> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fff88282000 - 0x7fff88293ff7  libsystem_trace.dylib (201.10.3) <25104542-5251-3E8D-B14A-9E37207218BC> /usr/lib/system/libsystem_trace.dylib
    0x7fff88294000 - 0x7fff88294ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
    0x7fff88295000 - 0x7fff882c3ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fff88347000 - 0x7fff8834affb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
    0x7fff88357000 - 0x7fff88362fff  libGL.dylib (12.0.40.6) <4FC6D3F9-6582-3E7D-A7D1-E035F0E26697> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fff88363000 - 0x7fff88367fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
    0x7fff884a8000 - 0x7fff884a9fff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
    0x7fff884f5000 - 0x7fff884fdfef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
    0x7fff884fe000 - 0x7fff8871fff7  com.apple.CoreImage (11.4.0 - 366.4.19) <6EE4A686-50C8-3D77-A036-BE8AA0F8A2FD> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fff88c2e000 - 0x7fff88c4cff7  libsystem_kernel.dylib (3248.40.184) <88C17B7F-1CD8-3979-A1A9-F7BDB4FCE789> /usr/lib/system/libsystem_kernel.dylib
    0x7fff88c4d000 - 0x7fff88c6ffff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fff89170000 - 0x7fff8922afff  com.apple.DiscRecording (9.0.1 - 9010.4.3) <540853B2-B123-3560-8023-C92EE229051A> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
    0x7fff89239000 - 0x7fff89250fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
    0x7fff892ce000 - 0x7fff892d1fff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fff892d2000 - 0x7fff892d3fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
    0x7fff89309000 - 0x7fff89341ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fff8937e000 - 0x7fff8946efff  libJP2.dylib (1444) <27371567-A122-3217-ADA0-3A446EF6A3E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fff8946f000 - 0x7fff894bdfff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
    0x7fff894c2000 - 0x7fff894c3fff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
    0x7fff89705000 - 0x7fff89716ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
    0x7fff89cb6000 - 0x7fff89cecfff  libssl.0.9.8.dylib (59.40.2) <523FEBFA-4BF7-3A69-83B7-164265BE7F4D> /usr/lib/libssl.0.9.8.dylib
    0x7fff89ced000 - 0x7fff89d07ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
    0x7fff89e02000 - 0x7fff89f80fff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fff89fa3000 - 0x7fff89facff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
    0x7fff8a73f000 - 0x7fff8a79cfff  com.apple.CoreServices.OSServices (728.8 - 728.8) <4CE49D8A-8304-3347-9379-6075CB906419> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fff8a79d000 - 0x7fff8a9aafff  libicucore.A.dylib (551.51) <35315A29-E21C-3CC5-8BD6-E07A3AE8FC0D> /usr/lib/libicucore.A.dylib
    0x7fff8a9ab000 - 0x7fff8a9adfff  libCVMSPluginSupport.dylib (12.0.40.6) <4AA6710A-6267-3062-BFF2-27DB5E6B5892> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fff8ac4c000 - 0x7fff8aee6fff  com.apple.security (7.0 - 57337.40.85) <7C5B8DEF-3D02-3410-9BD3-2B1251F84D4B> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fff8b1d0000 - 0x7fff8b1d5ff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
    0x7fff8b1e3000 - 0x7fff8b257ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fff8b258000 - 0x7fff8b2cffeb  libcorecrypto.dylib (335.40.8) <9D300121-CAF8-3894-8774-DF38FA65F238> /usr/lib/system/libcorecrypto.dylib
    0x7fff8b5ab000 - 0x7fff8b6cffff  libsqlite3.dylib (216.4) <280D67B8-F93D-3587-A146-19F36C817548> /usr/lib/libsqlite3.dylib
    0x7fff8b78b000 - 0x7fff8b7e7fff  libTIFF.dylib (1444) <2A22E6B7-213B-3253-838F-C3EC3C8F2727> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fff8b7fb000 - 0x7fff8b82eff7  com.apple.MediaKit (16 - 809) <BF8032FE-6645-37F6-A622-BC7EEE3EAABF> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
    0x7fff8b82f000 - 0x7fff8b89efff  com.apple.datadetectorscore (7.0 - 460) <8EF4EECC-4FF1-36DF-84CF-65545555A225> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fff8b89f000 - 0x7fff8b8d1ff7  libTrueTypeScaler.dylib (158.5) <EA63B45B-22D3-3546-9BD6-EEEB7F1B48B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fff8b8d2000 - 0x7fff8b8e0fff  com.apple.opengl (12.0.40 - 12.0.40) <AEA28993-BA3E-3E0F-A2F5-88C312ABB634> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fff8b8e1000 - 0x7fff8b985fff  com.apple.Bluetooth (4.4.4 - 4.4.4f4) <BCF89EFE-853D-3AEA-AE31-DC8293C7284F> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fff8bf7d000 - 0x7fff8bfa2ff7  libPng.dylib (1444) <47ACF98D-B5F1-3A03-B6FD-4107D5FAE5E9> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fff8c042000 - 0x7fff8c059ff7  libsystem_asl.dylib (323.40.3) <007F9094-317A-33EA-AF62-BAEAAB48C0F7> /usr/lib/system/libsystem_asl.dylib
    0x7fff8c05a000 - 0x7fff8c062fef  libcldcpuengine.dylib (2.7.3) <B385841A-B573-3A91-9BEB-CC89CB2716B3> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fff8c0c6000 - 0x7fff8c0c9fff  com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fff8c0ca000 - 0x7fff8c15ffff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fff8c176000 - 0x7fff8c19ffff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
    0x7fff8c1a0000 - 0x7fff8c1b3fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fff8c1bd000 - 0x7fff8c1ecffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
    0x7fff8c225000 - 0x7fff8c36fff7  com.apple.coreui (2.1 - 366.1) <A3868F31-ACF4-3EA5-9E75-79ED44FA7F06> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fff8c370000 - 0x7fff8c3e4ff3  com.apple.securityfoundation (6.0 - 55126) <1F6BDF18-3CF0-3E85-8D9B-0663599B9949> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fff8c3e5000 - 0x7fff8c3fffff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fff8c400000 - 0x7fff8c402ff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
    0x7fff8c407000 - 0x7fff8c408ffb  libSystem.B.dylib (1226.10.1) <CD307E99-FC5C-3575-BCCE-0C861AA63124> /usr/lib/libSystem.B.dylib
    0x7fff8c596000 - 0x7fff8c598fff  libCGXType.A.dylib (957) <B901C222-E779-32EB-96C2-5A707A09FC5B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
    0x7fff8c599000 - 0x7fff8c5ffff7  libsystem_network.dylib (583.40.20) <269E5ADD-6922-31E2-8D55-7B777263AC0D> /usr/lib/system/libsystem_network.dylib
    0x7fff8c600000 - 0x7fff8c609fff  com.apple.icloud.FindMyDevice (1.0 - 1) <B9C741F2-6FAC-3BA7-B6E0-9A910C6E8D4E> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
    0x7fff8c60a000 - 0x7fff8c60afff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
    0x7fff8c60b000 - 0x7fff8c60effb  libdyld.dylib (360.21) <8390E026-F7DE-3C32-9486-3DFF6BD131B0> /usr/lib/system/libdyld.dylib
    0x7fff8c60f000 - 0x7fff8c640fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fff8c641000 - 0x7fff8c64cfff  libcsfde.dylib (517.20.1) <6FFC376E-E141-37EE-800A-004080A50091> /usr/lib/libcsfde.dylib
    0x7fff8c64d000 - 0x7fff8c6d6ff7  com.apple.PerformanceAnalysis (1.0 - 1) <608E8C50-6F59-3FEB-B822-D9B02F328716> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fff8c720000 - 0x7fff8c725fff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fff8c755000 - 0x7fff8c760fff  libkxld.dylib (3248.40.184) <6F776D34-D06C-3C48-B753-D0FB375A4A8A> /usr/lib/system/libkxld.dylib
    0x7fff8c761000 - 0x7fff8c7f0ff7  libCoreStorage.dylib (517.20.1) <EC540EAA-089C-36D9-BBAA-0684EDE098AB> /usr/lib/libCoreStorage.dylib
    0x7fff8c852000 - 0x7fff8c854fff  com.apple.EFILogin (2.0 - 2) <38150198-DD7F-3C73-BCAA-C74BB376393A> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
    0x7fff8d7d9000 - 0x7fff8d7ddfff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
    0x7fff8d7de000 - 0x7fff8d81fff7  libGLU.dylib (12.0.40.6) <C56DDF90-CF6D-30D2-A3E6-89288BE69DCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fff8d820000 - 0x7fff8d823ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fff8d824000 - 0x7fff8da2ffff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
    0x7fff8da30000 - 0x7fff8da81ff7  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <3D62A9B3-67A8-3F8A-A102-05E310249075> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fff8da82000 - 0x7fff8da82fff  libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fff8da95000 - 0x7fff8da96ff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
    0x7fff8da97000 - 0x7fff8dae3ffb  com.apple.HIServices (1.22 - 549) <E4E1BD10-F475-3E19-9E0B-A5071D158F47> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fff8dae4000 - 0x7fff8dc11ff3  com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fff8dc41000 - 0x7fff8dc5afff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fff8dc5b000 - 0x7fff8dc7dff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fff8dc7e000 - 0x7fff8dca2fff  libJPEG.dylib (1444) <AECB826C-8B14-3D04-8DEC-33EE85F5150D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fff8dca3000 - 0x7fff8dcc7fff  com.apple.MultitouchSupport.framework (304.10.2 - 304.10.2) <CE75EDA3-2B22-3968-834E-550EA870ECC8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fff8dd76000 - 0x7fff8de03fff  libsystem_c.dylib (1082.20.4) <CDEBF2BB-A578-30F5-846F-96274951C3C5> /usr/lib/system/libsystem_c.dylib
    0x7fff8e50b000 - 0x7fff8e513fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
    0x7fff8e515000 - 0x7fff8e51dfff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
    0x7fff8e527000 - 0x7fff8e55eff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
    0x7fff8e55f000 - 0x7fff8e57eff7  com.apple.framework.Apple80211 (11.0 - 1121.34) <AE7795B8-4590-3714-999D-3FBFF6BF5D93> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fff8e678000 - 0x7fff8e67fff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
    0x7fff8e6d2000 - 0x7fff8e839fff  libBLAS.dylib (1162.2) <A1398FE0-39D2-33EA-9A0F-B2644EEA29A0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fff8e843000 - 0x7fff8e843fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <185EC96A-5AF0-3620-A4ED-4D3654D25B39> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fff8e859000 - 0x7fff8e871fef  libcompression.dylib (28) <E7601B62-1053-369D-8A9E-91CF86239220> /usr/lib/libcompression.dylib
    0x7fff8e879000 - 0x7fff8e8beff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fff8f1eb000 - 0x7fff8f214fff  com.apple.ProtectedCloudStorage (1.0 - 1) <4850F751-E61B-30C0-B89A-B313601D3DB5> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
    0x7fff8f346000 - 0x7fff8f348ff7  libRadiance.dylib (1444) <A5EFA292-AFD4-3FCE-8802-958AD60F75DA> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fff8f349000 - 0x7fff8f354ff7  libcommonCrypto.dylib (60075.40.2) <B9D08EB8-FB35-3F7B-8A1C-6FCE3F07B7E7> /usr/lib/system/libcommonCrypto.dylib
    0x7fff8f43f000 - 0x7fff8f525ff7  libcrypto.0.9.8.dylib (59.40.2) <2486D801-C756-3488-B519-1AA6807E8948> /usr/lib/libcrypto.0.9.8.dylib
    0x7fff8f52f000 - 0x7fff8f60fff7  unorm8_rgba.dylib (2.7.3) <9EB6C346-CFF6-32D7-B4A1-2409DFBCB216> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_rgba.dylib
    0x7fff8ff41000 - 0x7fff8ff5eff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <F4AF2363-B28E-3097-AB1E-FDA1C92F8F56> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
    0x7fff8ff6f000 - 0x7fff8ffb5ff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
    0x7fff8ffee000 - 0x7fff90041ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
    0x7fff9005f000 - 0x7fff90088ff7  libxpc.dylib (765.40.36) <2CC7CF36-66D4-301B-A6D8-EBAE7405B008> /usr/lib/system/libxpc.dylib
    0x7fff900a8000 - 0x7fff901b6ff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fff906a7000 - 0x7fff906a9ff7  com.apple.securityhi (9.0 - 55006) <A4CEFD45-C51C-381C-A57B-FF75D90C680F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
    0x7fff9072a000 - 0x7fff9072cff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
    0x7fff907de000 - 0x7fff90a74fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
    0x7fff90a75000 - 0x7fff90cfcff7  com.apple.CFNetwork (760.4.2 - 760.4.2) <24C4A390-3079-358A-8D51-75A3E818A6DF> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fff90cfd000 - 0x7fff90d05fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
    0x7fff90f45000 - 0x7fff90f4dfff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
    0x7fff917c5000 - 0x7fff917ecfff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fff917f2000 - 0x7fff9187fdd7  com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fff918a9000 - 0x7fff918b5fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fff918b6000 - 0x7fff91907ff7  libcups.2.dylib (435.1) <4198A94D-A46C-39AA-92B6-83D0BA507D6C> /usr/lib/libcups.2.dylib
    0x7fff91908000 - 0x7fff91aaeff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fff91cb5000 - 0x7fff91cdefff  libsystem_info.dylib (477.40.5) <6B01C09E-A3E5-3C71-B370-D0CABD11A436> /usr/lib/system/libsystem_info.dylib
    0x7fff92647000 - 0x7fff929dcfdb  com.apple.vImage (8.0 - 8.0) <4BAC9B6F-7482-3580-8787-AB0A5B4D331B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fff929dd000 - 0x7fff92a44fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fff92a45000 - 0x7fff92a47fff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fff92b6c000 - 0x7fff92bdaff7  com.apple.ApplicationServices.ATS (377 - 394.3) <847DBFBA-8D6B-367B-99FD-C6CAA8C05C65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fff92c18000 - 0x7fff92c23ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
    0x7fff92d8b000 - 0x7fff92d8eff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
    0x7fff92d8f000 - 0x7fff92da0fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
    0x7fff92e07000 - 0x7fff92e55ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
    0x7fff92f3e000 - 0x7fff92f67ffb  libRIP.A.dylib (957) <5F18F20D-5921-3314-A9F8-F1B1CB62C83D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
    0x7fff93886000 - 0x7fff938afff7  libxslt.1.dylib (14.1) <27DE3F2E-CE96-3327-A563-788EE3E2775B> /usr/lib/libxslt.1.dylib
    0x7fff938b5000 - 0x7fff93c09fff  com.apple.Foundation (6.9 - 1258) <51833143-6CAE-3E1C-9FBA-BCDEB48D4ADF> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fff93ca2000 - 0x7fff93cbeff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
    0x7fff93d2a000 - 0x7fff93d3afff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
    0x7fff93d3b000 - 0x7fff93d7dff7  com.apple.Metal (56.6 - 56.6) <7DCBE573-B713-3C50-A16E-2F33A84C3CFB> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fff93e36000 - 0x7fff942acfff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fff943dc000 - 0x7fff943f8ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
    0x7fff9445b000 - 0x7fff9454dff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
    0x7fff9454e000 - 0x7fff94553fff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
    0x7fff94554000 - 0x7fff94560fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fff951b4000 - 0x7fff951b4ff7  liblaunch.dylib (765.40.36) <1CD7619D-AF2E-34D1-8EC6-8021CF473D9B> /usr/lib/system/liblaunch.dylib
    0x7fff95427000 - 0x7fff95430ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fff95431000 - 0x7fff95433fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
    0x7fff95441000 - 0x7fff95449ffb  libsystem_dnssd.dylib (625.40.20) <86A05653-DCA0-3345-B29F-F320029AA05E> /usr/lib/system/libsystem_dnssd.dylib
    0x7fff95450000 - 0x7fff9546bff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
    0x7fff9546c000 - 0x7fff9546cfff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <054DFE32-737D-3211-9A14-0FC5E1A880E3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fff96b07000 - 0x7fff97d52feb  com.apple.CoreGraphics (1.600.0 - 957) <8C9F8E1A-274C-36CE-93FB-49906A9B9EE2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fff97d53000 - 0x7fff97e39fef  unorm8_bgra.dylib (2.7.3) <B315AE9C-9E09-3D9F-9513-EC2195908516> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
    0x7fff97fe0000 - 0x7fff97ffcfff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fff98019000 - 0x7fff9801affb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
    0x7fff982d7000 - 0x7fff982ebfe3  libCGInterfaces.dylib (317.9) <5079DE4F-3717-32FF-B76A-77F53236D17D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fff98339000 - 0x7fff98341fff  libGFXShared.dylib (12.0.40.6) <1CDE5AEF-3E44-3547-879E-BB490EE7702C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fff98342000 - 0x7fff986a4f3f  libobjc.A.dylib (680) <7489D2D6-1EFD-3414-B18D-2AECCCC90286> /usr/lib/libobjc.A.dylib
    0x7fff986a5000 - 0x7fff986bcff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
    0x7fff986bd000 - 0x7fff98709fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fff9870a000 - 0x7fff98713ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
    0x7fff988e8000 - 0x7fff98bddfff  com.apple.HIToolbox (2.1.1 - 807.2) <871E5223-5D03-3649-98AF-9CCA3B41E307> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fff98cd6000 - 0x7fff98cd6ff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
    0x7fff98cd7000 - 0x7fff98d11fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fff98d12000 - 0x7fff98d17fff  com.apple.TCC (1.0 - 1) <50F7EC60-5B21-3B9B-BF2F-F037EA7B12FB> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fff98d18000 - 0x7fff98d20fff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fff98d5d000 - 0x7fff98e82ff7  com.apple.LaunchServices (728.8 - 728.8) <FDA38B17-82E2-322F-A008-B9207A6EA668> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fff99037000 - 0x7fff992ddff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fff9941d000 - 0x7fff99422ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
    0x7fff99423000 - 0x7fff99472ff7  com.apple.opencl (2.7.0 - 2.7.0) <307263BA-0368-38C9-A7FB-25920343D0DF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fff99473000 - 0x7fff99482ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fff99483000 - 0x7fff994c8ff3  libFontRegistry.dylib (155.1) <F3355C6E-ED33-3506-B10E-2F6995D34BC1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fff994c9000 - 0x7fff994f8ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fff995b3000 - 0x7fff9963bfff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fff99688000 - 0x7fff996c2ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fff996db000 - 0x7fff996e9fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
    0x7fff99783000 - 0x7fff9978efff  com.apple.CrashReporterSupport (10.11 - 717) <474544AD-1199-3ECC-90E5-071847BA72C6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fff99c2b000 - 0x7fff99d27ff7  libFontParser.dylib (158.5) <62796E99-36B7-36B6-8D33-5349F88014C3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fff99e97000 - 0x7fff99f2dfff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fff99f2e000 - 0x7fff9a32afff  libLAPACK.dylib (1162.2) <987E42B0-5108-3065-87F0-9DF7616A8A06> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fff9a333000 - 0x7fff9a334fff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fff9a35f000 - 0x7fff9a40ffe7  libvMisc.dylib (563.5) <6D73C20D-D1C4-3BA5-809B-4B597C15AA86> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fff9a41c000 - 0x7fff9a422ff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fff9a423000 - 0x7fff9a481fff  com.apple.SystemConfiguration (1.14 - 1.14) <10082F58-6190-3A7C-8B6C-C12B16DC793A> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fff9a487000 - 0x7fff9a55dffb  com.apple.DiskImagesFramework (10.11.3 - 417.2) <7412BC0B-A895-350D-B829-1E3A6FF5EC3F> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x7fff9a628000 - 0x7fff9a6d8fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fff9a6d9000 - 0x7fff9a744ff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fff9ad7e000 - 0x7fff9adedfff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fff9ae66000 - 0x7fff9ae66fff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
    0x7fff9ae67000 - 0x7fff9ae67fff  com.apple.CoreServices (728.9 - 728.9) <78CB3EAC-A66E-3FD9-A1DF-A9CF227ED3C3> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fff9aeed000 - 0x7fff9b0b3fe7  com.apple.ImageIO.framework (3.3.0 - 1444) <54F18254-F31B-3464-BB51-BAF9E9620419> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    External Modification Summary:
      Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
      Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
      Calls made by all processes on this machine:
    task_for_pid: 15697
    thread_create: 0
    thread_set_state: 0
    VM Region Summary:
    ReadOnly portion of Libraries: Total=239.4M resident=0K(0%) swapped_out_or_unallocated=239.4M(100%)
    Writable regions: Total=234.5M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=234.5M(100%)
                                VIRTUAL   REGION
    REGION TYPE                    SIZECOUNT (non-coalesced)
    Accelerate.framework           128K    2
    Activity Tracing              2048K    2
    CG backing stores             10.9M    7
    CG image                        68K   12
    CG shared images               464K   12
    CoreAnimation                  196K   11
    CoreUI image data             1596K   12
    CoreUI image file              192K    4
    Dispatch continuations        16.0M    2
    Foundation                       4K    2
    Kernel Alloc Once                8K    3
    MALLOC                       171.3M   58
    MALLOC guard page               32K    8
    Memory Tag 242                  12K    2
    OpenCL                           8K    2
    Process Corpse Info           2048K    2
    STACK GUARD                   56.1M   15
    Stack                         14.2M   16
    VM_ALLOCATE                     56K    8
    __DATA                        18.5M  207
    __IMAGE                        528K    2
    __LINKEDIT                    91.6M    6
    __TEXT                       147.7M  213
    __UNICODE                      552K    2
    mapped file                   47.9M   19
    shared memory                 16.3M    8
    TOTAL                        598.2M  611
    autodeskguest over 12 years ago in reply to e14 Contributor
    On 9/17/2014 1:10 AM, Ben Cannon wrote:
    Hi Jorge, thank you for chiming in.
    I mean crashing.  As in, "The application EAGLE unexpectedly quit, click
    here to reopen".
    I see that the top router does take a lot longer, but it does seem to
    produce some exciting results.
    It looks like none of the auto routers are able to route a board of any
    complexity that incorporates a ground plane. (Why it doesn't simply add
    Vias to reconnect a "fallen apart" ground plane is beyond me.)   Just
    auto routing the GND class/net with via cost way down produces a
    beautiful result, but as soon as the rest of the board is routed with
    ground/VCC planes, everything goes to heck.  But that's another story.
    I've got to get around these crashes first, it's all but completely
    un-useable now, the crashes are 100% now, somewhere between 5 and 15min
    into an autoroute (that looks like it should be a multi-hour process
    with my settings.)
    Hi Ben,
    Let's make sure you're permissions for EAGLE are setup correctly first.
    The crash time you're talking about 5 to 15 min is close to the
    automatic backup generation interval. If EAGLE isn't permitted to
    perform the backup, then it will crash.
    Here's the procedure to setup EAGLE's permissions
    1. Open Finder.
    2. Navigate to Application
    3. right click on EAGLE-7.1.0 Folder and select “Get Info”
    4. left click on the lock symbol at the bottom right and log into your
    admin account.
    5. select the plus sign on the bottom left and add your login name to
    the access list.
    6. select your access list the change it to read & write.
    7. left click on the lock symbol to close access to permission changes.
    hth,
    Jorge Garcia
    e14 Contributor over 12 years ago in reply to autodeskguest
    I mean crashing.  As in, "The application EAGLE unexpectedly quit, click here to reopen".
    I see that the top router does take a lot longer, but it does seem to produce some exciting results.
    It looks like none of the auto routers are able to route a board of any complexity that incorporates a ground plane. (Why it doesn't simply add Vias to reconnect a "fallen apart" ground plane is beyond me.)   Just auto routing the GND class/net with via cost way down produces a beautiful result, but as soon as the rest of the board is routed with ground/VCC planes, everything goes to heck.  But that's another story.
    I've got to get around these crashes first, it's all but completely un-useable now, the crashes are 100% now, somewhere between 5 and 15min into an autoroute (that looks like it should be a multi-hour process with my settings.)
    On 9/15/2014 10:02 PM, Ben Cannon wrote:
    I have an urgent project that constantly crashed the autorouter
    approximately 90% of the time.  The system is unusable, and while
    tweaking the auto router and doing things like routing the ground plane
    first eventually produced a 100% route, the polygons subsequently "fall
    apart" on my ground plane, completing only 80% of the only fairly
    complex board.
    System has 24 cores at 3.46Ghz and 64GB of ram...
    Is this software just junk?
    http://www.element14.com/community/message/126511
    Hello Ben,
    I hope you're doing well. Define "crash", do you mean EAGLE actually
    closes or does it just seem to stop working. The pre-router variant can
    take a while to process. To test this run the autorouter but uncheck the
    prerouter option that shows up in the first dialog after you click on
    the autorouter.
    Keep in mind that an autorouter is a tool, and being a designer involves
    knowing when to use one tool over the other. Polygons fall apart when
    too many traces run through them and isolated islands of copper form. If
    you have any high-speed or high-power signals don't use the autorouter.
    If you have any low level signals to process don't use the autorouter.
    Your hardware can't be fully leveraged by EAGLE so past a certain point
    having more ram or cores doesn't produce any improvement in processing time.
    hth,
    Jorge Garcia
