EAGLE User Support (English) Annoying behavior of renumber-sheet.ulp
  • Views 992 views
autodeskguest over 12 years ago
I'm talking about the renumber-sheet.ulp, which by default is now also
accessible via menu item (Eagle V6.60/Script V5.0.1)
I really like it, but one annoying issue is: I have a project with
several sheets, and renumber the parts so that the hundreds of part
number reflect sheet number e.g. 1xx sheet 1, 2xx sheet 2 and so on.
I have manually renamed several connectors which were with the device
name prefixing as "X" (some Wago clamps from a downloaded lib), e.g.
when you place the part on an empty schematic it will show up as X1, I
renamed it manually to lets say ST2.
I also added my connectors from my library, which always start with
prefix "ST" so you will end up placing it as ST1 and so on.
When I now renumber my project, I expect my ST1 renamed to ST100 and the
manually renamed ST2 to ST101.
What happens is, I end up with ST101 and X101.
Why does the ULP even dare to touch any prefix?
I'm aware of this "Do not renumber parts with Prefixes (separated
by';')" Textfield, but that would not help me as I WANT my ST1,ST2,ST3
renamed to ST101,ST102 etc.
Why does the ULP not split up Prefix and Number of each part and just
changes the numerical part?
Can someone please fix this? It will take me an hour to rename all my
connectors now (large project)
Markus
  • Anonymous-543084
    Anonymous-543084 over 8 years ago in reply to e14 Contributor
    The same problrm  here. Version 7.7.0. Schematic >  menu Tools --> Renumber parts
    lbr_pcb.zip
    autodeskguest over 8 years ago in reply to e14 Contributor
    https://www.element14.com/community/message/230498
    autodeskguest over 12 years ago in reply to e14 Contributor
    On 24.09.2014 08:47, A. Zaffran wrote:
    Hello Markus,
    please send me the schematic and the library.
    Alfred Zaffran
    Will do later. Sorry, busy right now.
    Am 24.09.2014 um 08:22 schrieb Markus Rudolf:
    Markus
    Hello Markus,
    Alfred Zaffran
    • The new EAGLE V7 has landed *
                                 Web:   <www.cadsoft.de>
    Geschaeftsfuehrer: Mark Whiteling
