EAGLE User Support (English) How to route a board (flex) wider than 4 meters ?
  • Subscribers 179 subscribers
  • Views 359 views
  • huge
  • wide
  • bigger
  • Big
lcdvasrm
lcdvasrm over 11 years ago
How to route a board (flex) wider than 4 meters ? Lets say 5 meters wide.
How can I remove the 4 meters limit (+-2000mm) in the coordinates in the board editor ?
Is it by changing somewhere the resolution ?
Will I still be able to export a gerber file that can be understood by manufacturers ?
I use eagle v6.5.0
If it is not possible,
If i design my board at an artificial scale 1/2 and export in gerber,
is there a trick in the gerber format or a simple edit i could do that would change it back to the right scale ?
    autodeskguest over 11 years ago +1
    On 30/10/2014 11:45 p.m., Laurent Laurent wrote: How to route a board (flex) wider than 4 meters ? Lets say 5 meters wide. How can I remove the 4 meters limit (+-2000mm) in the coordinates in the board…
    autodeskguest over 11 years ago in reply to autodeskguest +1
    On 30/10/14 19:51, warrenbrayshaw wrote: On 30/10/2014 11:45 p.m., Laurent Laurent wrote: How to route a board (flex) wider than 4 meters ? Lets say 5 meters wide. How can I remove the 4 meters limit …
    wide.
    board editor ?
    manufacturers ?
    I use eagle v6.5.0
    http://www.element14.com/community/message/129928
    You wont be able to change the Eagle internal units or the Gerber Eagle
    generates. The output will be to size but you could scale up by changing
    the units from mm to inches by modifying the gerbers manually.
    I suggest you contact the company that will make this for you. They will
    provide the guidance for the files they require. Often their web site
    will provide that information.
    HTH
    Warren
    wide.
    board editor ?
    manufacturers ?
    I use eagle v6.5.0
    HTH
    Warren
    Hi Lauren,
    If you can code a little bit, there is libgerbv (part of the gerbv
    package) that allows scaling, mirroring, highlighting, rotating etc. . I
    use it to produce placement drawings (the outlines and names highlighted).
    http://gerbv.geda-project.org/doxygen/index.html
    Hth,
    Bob
  • lcdvasrm
    lcdvasrm over 11 years ago in reply to autodeskguest
    Thanks to booth of you,
    gerbv even handles the excellon files. Good.
    I will ask first to our manufacturers if they can scale themselves.
  • lcdvasrm
