EAGLE User Support (English) adding lonely wire to schematic/board
  • Subscribers 179 subscribers
  • Views 444 views
e14candies
e14candies over 11 years ago
I have a board full of parts, no problem with the schematic or layout.
However, I also have a few wires that get soldered to the board in random
locations, say Fred here & Sam there, they solder to some vias (NOT
connectors)...they run some zigzag traces then leave the board by wire at
different vias.  These traces do not connect to any components.
How do I show these via (incoming)-to-via(outgoing) wires on my schematic
so they'll show as required traces on my board editor?
  • e14candies
    After poking around some more, it appears I can use the wirepad library
    "components"...is this correct, or is there another/better way?
    autodeskguest over 11 years ago in reply to e14candies
    If I've properly understood what you intend, it seems a perfectly
    reasonable method.
  • dukepro
    dukepro over 11 years ago
    I've been faced with this same problem on several occasions.  I don't
    necessarily want to clutter the schematic with single-pad devices just
    to show a manually installed wire.  You can do this, to be sure, but it
    creates separate nets when in fact they are the same net, and that
    defeats some QA in that you can't "Show N$x" to highlight the entire net.
    Like you, I leave via's at the wire end points as well.  But I'll also
    employ one of the unused inner layers and rename it "JUMPERS".  Then
    I'll route a 100 mil wide wire on that layer showing the intended path
    of installation.  This allows for handy documentation for the assembly
    house.  i.e. export an imageer.png showing the board outline, vias,
    (maybe pads, too), tPlace, and JUMPERS.
    For the wire width of jumpers, I usually use something really obtuse,
    like 100 mil wide.  I'll also change the color and fill pattern of the
    JUMPERS layer to make it painfully obvious.
    The setup to allow use of an inner layer is in the DRC dialog.  Click on
    the Layers tab and change the "Setup" text field.  For a 4-layer board,
    I have "(123*15+16)", using layer 3 as the JUMPERS layer.  An example
    is below.
    HTH,
        - Chuck
    Example of using a JUMPERS layer
    1524.att1.html.zip
    autodeskguest over 11 years ago in reply to dukepro
    I didn't think that was what the OP wanted to do. I might be wrong, though.
  • e14candies
    e14candies over 11 years ago in reply to autodeskguest
    though.
    Tis correct, I just wanted a wire coming to the board, routing through the
    board (connecting to nothing) then exiting the board at a different wire.
    I wasn't sure how to put it in the schematic to force routing (such as
    autoroute), but it looks like wirepads are the answer.
    The tips for board wire jumpers are appreciated, since I might need some of
    those as well.
