EAGLE User Support (English) Importing gerber RS274-X format?
  • Views 1261 views
dizzwold
dizzwold over 11 years ago
I'm new to Eagle and i've found a gerber file on Microchips website that i'd like to import in to Eagle to play with the Schematic and Board.
How do i do so? The file is RS274-X format. I have Eagle Pro 6.5.0.
USB2514 Full Speed USB 2.0 4 Port Hub Customer Evaluation Board - evb-usb2514b-fs | Microchip Technology Inc.
EVB-USB2514B-FS Evaluation Board Gerber Files
dizzwold.
  • dizzwold
    dizzwold over 11 years ago in reply to autodeskguest
    Hi Jorge,
     Thank you again for your reply, input and tolerance.As i explained, i'm new to Eagle. So far i've had good results, but i think this has been more luck than judgment!I love the Eagle format, but when it comes to things like this, i think it lets itself down somewhat 'lack of info, or, how to's'.
     I'll have another try tomorrow, after the GP 'maybe monday as a few beers will be involved' not a good mix".
     'LETS SEE IF ITS A SPA FRANCORCHAMPS REPEAT'!!!
     D.
    autodeskguest over 11 years ago in reply to dizzwold
    On 11/20/2014 7:22 PM, Darren Simms wrote:
    Hi Jorge,
      No joy.
    I drag BOT.PHO to the GBR274X6 icon, it opens and i enter 101 'press
    enter', 102 'press enter' when asked for the layer #s. This has already
    added a SCR file beneath the BOT.PHO file.  With this still open i then
    open a new eagle board and then click the 'execute script' , button?
    I've tried to get the new BOT file into Eagle, but nothing?
      Is there a YOUTUBE of this?
    Hi Darren,
    I don't believe there's a youtube video of this. You're very close
    though. Since you already got the script which is the hardest part. To
    bring it into EAGLE these are the next steps.
    1. In the board click on the SCR icon, or type the word SCRIPT followed
    by pressing the Enter key on your keyboard. This will open a new dialog
    window.
    2. In the dialog window browse for the SCR file that was generated.
    3. Once you find it double-click on it to make it run.
    hth,
    Jorge Garcia
  • dizzwold
    Hi Jorge,
    No joy.
    I drag BOT.PHO to the GBR274X6 icon, it opens and i enter 101 'press enter', 102 'press enter' when asked for the layer #s. This has already added a SCR file beneath the BOT.PHO file.  With this still open i then open a new eagle board and then click the 'execute script' , button? I've tried to get the new BOT file into Eagle, but nothing?
    D.
    On 11/20/2014 3:27 PM, Darren Simms wrote:
    Hi Jorge,
      Thank you for your advise.
    Once i've download the file you list above GBR274X6zip and unzip it,
    what do i do next.
    It opens a terminal like window???
    I've tried copying one of the files into the terminal window, but i just
    get error 76???
    Hi Darren,
    The best way I've found to use these very old tools is to draw the
    gerber file over the icon of the executable. That will take care of all
    of the path issues. From there the utility will ask for a couple of
    layers, I usually type 101 and 102. The selection of layers is arbitrary
    I pick numbers higher than 100 so that I can distinguish them from
    EAGLE's default layer setup.
    Once the script is done it will generate a .scr file. You can run this
    file on your board by clicking on the script icon (top toolbar 8 or 9th
    from the left). Then browse to the file and click open.
    Best Regards,
    Jorge Garcia
  • dizzwold
    Hi Jorge,
    Once i've download the file you list above GBR274X6zip and unzip it, what do i do next.
    I've tried copying one of the files into the terminal window, but i just get error 76???
    Sorry for being stupid, but i've never done this before and as stated, still learning my way around Eagle.
    dizzwold.
    Hi Darren,
    I hope you're doing well. There are several tools for importing Gerbers
    into EAGLE. Most of them are rather old but they still work. Go to our
    website www.cadsoftusa.com>Downloads>Tools and Converters. Search for
    gerber and you'll see the available tools. I've used gbr274x6 in the
    past with success.
    hth,
    Jorge Garcia
