EAGLE User Support (English) Eagle Program Default Settings
  • Subscribers 186 subscribers
  • Views 1877 views
docholiday
docholiday over 11 years ago
Is there a way to reset/restore eagle back to factory default? as an example if you delete all the layers under Layer Settings how can it be restored back to program default settings.
    Hi Nicholas,
    I hope you're doing well. Find the eaglerc file on your system, make
    sure eagle is closed when you do this. Once you have found it, delete
    the file and then open EAGLE. When EAGLE can't find the eaglerc file it
    basically recreates the file and resets to it's default settings.
    Depending on your operating system the eaglerc file will have different
    names:
    eaglerc.usr(Windows), .eaglerc(mac and linux).
    Doing a file search including hidden files has usually worked well to
    find the file.
    Best Regards,
    Jorge Garcia
