EAGLE User Support (English) 0.65mm bga routing
  • Subscribers 187 subscribers
  • Views 887 views
0.65mm bga routing
Hi all. I am working on a project involving a 0.65mm pitch BGA chip. I am having trouble getting the vias under the BGA to a proper size, using the Sunstone PCB design rules. I see restring settings, I temporarily changed those to say drill diameter is 50% of outer layer diameter, I saw no change. I am (for now) using the free version of eagle cad. I found a document explaining proper routing under the BGA, basically putting vias in every other block of four pads.
Also, I am using about 50 of the 121 pads, is it possible to do everything on a two layer board?
Thank you.
    Am 17.07.2015 um 18:21 schrieb Scott Carlson:
    For the vias, please check the settings in the Design Rules' Restring
    tab. There are settings that decide about via diameters. Please check
    the minimum value. If you are not sure, pleae contact your board
    manufacturer and ask what is the best combination of drill size and
    via diameter....
    Richard Hammerl
    First, you can lock pad diameters within the device editor. I bet they
    are now set to "auto" and changes with restring settings.
    Second, you last question suggests makes me wonder what kind of BGA
    device you are working with. None of the ones I ever seen can only use
    50 of 121 pads, and even considering two layer boards make me think you
    are not serious. But let me know what device you are considering; You
    may surprise me.
