    • Avnet Boards Community
EAGLE User Support (English) Eagle License
  • Replies 12 replies
  • Subscribers 177 subscribers
  • Views 3911 views
  • license
  • upgrade
Eagle License
tadpole19
tadpole19 over 10 years ago
I have recently purchased Hobbyist/Non Commercial License for 7.2.0 for Linux.  There is a new version now available (7.3). May I use the purchased licesnse for 7.2 on the new version?
    Former Member over 10 years ago in reply to tadpole19 +1
    Hokay ... now I think we know what your problem is. For every Eagle install, there are typically two codes : License Code Installation Code (10 digit) When you register/buy you will typically get both…
    autodeskguest over 10 years ago in reply to Former Member +1
    Am 31.08.2015 um 00:35 schrieb Brendon Meyer: Hokay ... now I think we know what your problem is. For every Eagle install, there are typically two codes : License Code Installation Code (10 digit) When…
  • tadpole19
    tadpole19 over 10 years ago in reply to autodeskguest +1 verified
    Hello all, Here is the conclusion of my saga: Yesterday I called the CadSoftUSA support number (+1 954-237-0932). After explaining my circumstance and providing my serial number, I've got the 10 character…
    0 autodeskguest over 10 years ago in reply to tadpole19
    Tad Dragowski wrote on Sat, 29 August 2015 19:40
    I followed the upgrade procedure
    (https://shop.cadsoftusa.com/en/upgrade/) suggested by Bob Alexander
    above and I could not complete it because when asked to "Type in the
    Installation Code (ten lower case letters):" it did not know what to
    type, since original installation of 7.2 was in February.
    Again your problem doesn't make sense.  Go back to your log or wherever you
    recorded the installation code and type it in.
  • tadpole19
    0 tadpole19 over 10 years ago in reply to autodeskguest
    Hello all,
    • Yesterday I called the CadSoftUSA support number (+1 954-237-0932). After explaining my circumstance and providing my serial number, I've got the 10 character license code. Eagle 7.3 works as expected.
    • I retrospect I should have called CadSoft before posting my question on this board.  I didn't remember how I activated Eagle 7.2 back in February and forgot that I talked to the support team at CadSoftUSA.
    • I suspect that the 10 character license code was simply displayed during registration session after I was asked for 16 digit download code.
    If other users have experienced this, it may be useful to add an entry in the CadSoftUsa web under Training & Service -> FAQ:  How to upgrade Eagle from 7.x to 7.y?
    My sincere thanks to Richard, Brendon and others who helped me on this forum and to Ed at CadSoft for the support.
    To @CadSoft Guest (comment #6 & #11 above): both your comments seem a bit unfriendly. I would hope that all members of this community could follow the good example of folks like Richard and Brandon in the future.
