EAGLE User Support (English) break nets across pages without rerouting
  • Subscribers 178 subscribers
  • Views 243 views
  • rename
  • net
  • routing
Greetings folks...
    So my problem should be simple, but I can't find it.  I did try browsing for an answer, and haven't found anything that works.
I have a board with 6 different identical modules on it.  I did this by routing one module, then (v7.2) importing the drawing into a new one and organizing it on my board.   I then finished power connections, etc for parts that are only on the combined board.   This included +3v3 routing;  I have a single power supply, of course.   They are all on separate pages. However...   In the process of building these boards, I had one that shorted out the 3.3v power in one module.
It's difficult to trace that across six identical modules, and I hadn't added any break points.   I did in fact, get lucky in that power comes across only the top layer (4 layer board) and met each of the modules at only one connection point, so I could cut and isolate.   This was done.   What I would like to do now, is insert a zero ohm resistor/ or fuse at those locations.   Hindsight, and all that.
I just can't figure out how to do that, without eagle undoing all my routing when I rename the nets.    Anyone have a clue on what I need to do?  (Other than start over, thank you! :}  )
Jason
    Don't know what combination of things worked, but I finally managed to do it.
    Cheers...
