EAGLE User Support (English) Search/Find an element, how???
  • Replies 10 replies
  • Subscribers 180 subscribers
  • Views 2053 views
  • find
  • run
Joop14
Joop14 over 10 years ago
In the schematic editor, when I press Ctl-F, I get the dialog from the ULP "find".
My question is, how do I search for an element that has a value that contains the string "J113"?
Wildcards like * or ? don't seem to work. When I type the exact value PMBFJ113, it finds the element.
When I type J113 or *J113*, it doesn't find anything. What am I doing wrong?
Kind Regards,
Joop
    You should try xfind.ulp. Bind it to Ctrl-F and life just became a little easier.
    http://www.cadsoftusa.com/downloads/file/xfind.ulp
    Eric
  • Joop14
    0 Joop14 over 10 years ago in reply to autodeskguest
    Thanks!
    What I don't understand however, is why Cadsoft is not able to update / maintain their ulp's. Many of them need improvement, or they stopped working since version 7.
    Instead of adding connections with online parties, Cadsoft should work on the core of Eagle and their ulp's.
    For example:
    - board mirror view
    - exceptions for thermals in polygons
    - check used libraries / report missing libraries and inconsistencies during "update from libray" something like: Eagle library check
    - restrict layers for inner layers
    - LTSpice export on Linux
    - locale for printf() in ULP
    - after smash, properties of names and values are not updated from library anymore
    - save last modification date-time stamp in brd and sch file
    - X-ref for busses
    Wake-up Cadsoft team!
    0 autodeskguest over 10 years ago in reply to Joop14
    On 10/29/2015 9:55 AM, Joop14 wrote:
    Thanks!
    For example:
    - board mirror view
    This is possible with the mirror-board.ulp that ships with EAGLE
    There's a couple of ways to handle this already. For example within the
    library you can specify if certain pads should always use solid
    connections by unchecking the thermals box for the pad. The downside of
    that is that the pad always needs to be treated the same way.
    Another way to do that would be a polygon within a polygon, with the
    internal polygon having thermals off. Neither way is super nice but they
    work.
    (http://www.teuniz.net/eagle/eaglelibcheck/)
    +1, This one has gotten some movement lately but I wasn't involved in
    the final determination of EAGLE's roadmap so I don't know if that's in
    there.
    +1, I personally think it would be cleaner if polygons could assume some
    sort of restrict property that way you wouldn't need a separate layer.
    +1
    Not sure I understand this one, could you elaborate?
    library anymore
    I don't think this would be a good idea. Generally if you are assigning
    values in the schematic or board, you would not want a library update to
    change them. Could create confusion, unless I'm misunderstanding what
    you're asking for.
    This is already possible with the >LAST_DATE_TIME text variable. It
    updates every time you save the file, or are you asking for something else.
    - X-ref for busses
    This one is odd to me as well. In the case of a single net the XREF
    makes sense since you want to easily find other instances of that net. A
    bus however is a collection of nets, so I find an X-ref for a bus less
    useful since it's doesn't aid in finding a particular signal.
    Additionally, Bus labels can get pretty long so I'm sure there are cases
    where this would be inconvenient.
    The idea behind these comments is to show that if some form of
    workaround exists even if it's not the most convenient that usually
    makes a given feature medium to low prio. In the case of others I
    totally agree that we need them but determining priorities is very
    difficult because everyone has a different opinion and some of the
    heaviest opinions aren't coming from technical staff.
    I'm happy to see that first time ever we are really adding features
    progressively throughout a major version, instead of having the lions
    share up front and then sticking to bugfixes and minor tweaks as a
    version aged. Maybe some of the new stuff isn't all up your alley, but
    other users do find it useful.
    Thank you for your input we really appreciate.
    Best Regards,
    Jorge Garcia
  • Joop14
    Hello Jorge, I hope you are doing well.
    First of all, thank you for responding, I appreciate it.
    Thanks!
    For example:
    - board mirror view
    I don't like the fact that mirror-board act on the actual content of the board.
    Also, all coordinates are wrong when using this ulp to mirror the board.
    work.
    I'll try that.
    When you print the value of a float or double in a formatted string with printf(), the decimal separator will
    be a dot or a comma, depending on the locale settings of the pc i.e. in the US it will print 1.23 and in most
    countries in Europe it will print 1,23. This causes big problems, for example when printing values to a file
    in csv format.
    library anymore
    you're asking for.
    When I change a library (for example, I change the text size of the name and value) and then I do an
    update from library in a schematic, size of text of name and value of all instances will be updated, apart
    from the ones that are smashed. Why?
    Smash should only detach the name and value labels from the element for their position.
    Appearantly, it looses the ability to get updated from library.
    Eagle uses the date/time when it was last saved, not necessarily modified.
    The difference is subtle but important.
    For example, when I copy the file to another destination, the save date/time in Eagle changes
    but there are no modifications compared with the original.
    Another example, I send a copy of a schematic to somebody via email.
    He receives the schematic and saves it on his pc. The save date/time will be different despite the file
    has not been modified.
    What I would like to see is that Eagle stores the last modification date/time stamp in the schematic/board
    files. This will make it more clear if a file has been altered or not.
    - X-ref for busses
    As an example, I have an MCU with an 8-bit parallel databus in sheet 4. The datalines are attached to a bus
    with the name "databus". The bus suddenly stops at the border without any indication.
    In sheet 12 I draw the same bus with name "databus" where the datalines are connected to another chip.
    After printing the schematic, when reading sheet 4, how does one know where to find the other end of the bus?
    What about the broken IDF export?
    http://www.element14.com/community/thread/43949/l/idf-export-broken?displayFullThread=true
    Kind Regards,
    Joop
  • kikoun
    0 kikoun over 10 years ago in reply to Joop14
    Thanks!
    For example:
    - board mirror view
    Me too, when I need a mirrored view of a board, it's only because I have a board on my desk, and need to find a part or a net to put an oscilloscope on it. I don't want to change my board , certainly not !!
    I just need a mirrored view of it, simply because in real life, after designing a board virtually on a computer, I get a real one in my hand, I need to test it and sometime looking on the top is not enough !
    - X-ref for busses
    No, I think the Xref for bus is to locate the bus.
    It should work like net, and locate the position of the other XREF of the same bus (same bus = same bus name).
    Guillaume.
    0 autodeskguest over 10 years ago in reply to kikoun
    I which case what I do is print the bottom side, mirrored, to a PDF.
  • kikoun
    0 kikoun over 10 years ago in reply to autodeskguest
    It's what I do now but tell me how to you use the 'show @' command on printed pdf, how you follow net, how do you manage to highlight a net... I tried to click with my pen on the paper but nothing happen !!!!!
    More seriously... if some people ask this feature it's is not just for been annoying...(i know I'm no the only one to ask this...) maybe it because it would be easier to do some task....
    Guillaume.
    - board mirror view
    board.
    This is true, a better bottom view functionality has been requested and
    is on the wish list, but for now it's considered low prio because of
    what I mentioned before.
    in csv format.
    The complexities of supporting multiple languages ;). The CSV(character
    separated values) files that EAGLE generates by default use semicolons
    as the delimiter instead of commas probably for that same reason.
    As long as you let the semicolon be used as the delimiter then
    everything should work.
    from
    library anymore
    assigning
    to
    what
    you're asking for.
    their position.
    Smash basically removes all control from EAGLE and it gives it to you.
    However you leave a text after it is smashed that is how EAGLE is going
    to leave it when you do the update. It's the safest move.
    else.
    modified.
    Putting is in as an enhancement request.
    - X-ref for busses
    A
    less
    cases
    any indication.
    Putting in the enhancement request.
    Last I spoke to the Developers this was going to be in EAGLE, but I see
    that in V7.4.0 the ULP has not been updated. I don't think the Python
    script will be included but the improved ULP should have been brought
    into the EAGLE distribution. I'll follow up and see what happened.
    Best Regards,
    Jorge Garcia
  • Joop14
    Thank you Jorge, for bringing this under the attention (again) of the developers.
    It's very much appreciated.
    in csv format.
    Unfortunately, this is not the case.  Let's do an example. Let's assume for a second that all programs interpret the decimal separator in csv files according to the locale (which is not always the case by the way).
    Let's say we are in an european office and we export some Eagle board data by using an ulp.
    Values are written as floats, let's say wit a precision of three decimals. They will be printed with a comma as a decimal separator.
    Everything seems to work fine. Also some third party software that reeds our exported data.
    Now we send this exported data to an office in the US. Guess what's going to happen?
    Exactly, the software at the other end of the ocean will interpret the comma as a grouping charachter, effectively ignoring it.
    As a result, all values will be multiplied with thousand!
    To avoid mistakes, a ulp should be able to be in control about the locale or otherwise to make sure that with printf() the decimal separator charachter is defined, independent from the locale settings of the pc.
    Kind Regards,
    Joop
    our exported data.
    going to happen?
    Hi Joop,
    I disagree, both Excel and LibreOffice allow you to specify what the
    delimiter should be. You can select tabs, whitespace, commas,
    semicolons, etc.
    That's just my opinion though.
    Best Regards,
    Jorge Garcia
