EAGLE User Support (English) Differential Bus Naming Issue
  • Subscribers 177 subscribers
  • Views 250 views
  • naming
  • bus
  • differential
For example, buses are named D[0..7], resulting in D0, D1, ... D7. Differential buses have _P and _N appended, resulting in D0_P, D0_N, ... D7_P, D7_N. I can name individual nets with this format. However, when I try to make a bus and give it the name D[0..7]_P,D[0..7]_N, Eagle throws an error saying "Unexpected '_' ", meaning that the underscore is invalid. The work-around is to not use a bus, just a cluster of nets beside a thick blue line.
This format was taken from various places including http://www.element14.com/community/message/37820/l/differential-pair-signals-and-buses#37820, right from the horse's mouth. It says "To be able to define a differential pair bus, the bus naming convention will be extended to allow the ']' to be followed by "_P" or "_N" which results in the individual net/signal names ABC0_P, ABC1_P, ..., ABC31_P". Doesn't work.
Am I doing something wrong?
    Differential buses have _P and N appended, resulting in D0P, D0_N, ...
    (/message/37820/l/differential-pair-signals-and-buses#37820), right from
    the horse's mouth. It says "+To be able to define a differential pair
    names ABC0_P, ABC1_P, ..., ABC31_P+". Doesn't work.
    http://www.element14.com/community/message/169535
    Hi
    Your only mistake is interpreting that the functionality came to be.
    The quote was a statement of intent that was never implemented.
    The writer was one of the original creators/owner of Eagle and that post
    was about the time Eagle was sold to E14 so the work was not done by the
    new owner. There was a lot of discussion on the Cadsoft forum at that
    time as how to move forward with Eagle. Another discussion was the value
    of making 32 layers available. That idea did make the cut as you will know.
    HTH
    Warren
