EAGLE User Support (English) component editing
  • Replies 12 replies
  • Answers 3 answers
  • Subscribers 189 subscribers
  • Views 1858 views
  • footprint.
  • editing
  • part
  • eagle pcb
component editing
Hi Guys,
I have started using eagle recently. I am trying to design a PCB that includes nrf51822 device. I have downloaded the NRF51.lbr. While designing I could found that the number of pins is not correct in the part,  but package is correct. In part the pin number is 49 instead of 48. I want to delete the unwanted pin from the part and verify the connections. I have tried few tutorials. Most of them are for creating new library. I could not found a tutorial that helps my requirement. Any suggestion will be helpful. (If anyone is having the correct nrf51 library please help .)
thanks
  • clem57
    0 clem57 over 10 years ago in reply to e14 Contributor
    On each you may select Helpful Yes | No
    Clem
    Hi guys,
    All the answers seems to be right. I selected one as correct answer since i started designing with it. I could not find an option to select multiple answers. Right now I am continuing with the connecting the PAD to ground in the package in NordicSemi.lbr. I think I am in the proper way.
    Thanks to all
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    thank you very much Warren. Will check it and reply
    0 e14 Contributor over 10 years ago in reply to clem57
    hi Clem,
    Thank you for the quick reply and valuable support. I will check it and reply soon.
    0 e14 Contributor over 10 years ago in reply to shabaz
    Hi shabaz,
    Thank you very much for the quick reply. I would like to tell you that I am new to hardware design. So the VSS (marked yellow in the picture) represent the pad connection? Wish I could verify the connections before continue with the design. Only because the above part is developed and posted by some people who likes to help and support others. please give me a feedback.
    0 autodeskguest over 10 years ago in reply to e14 Contributor
    On 9/02/2016 6:00 a.m., rahul mon wrote:
    Hi ,
    I think the VSS is an extra pin in this library. The package used is
    QFN48
    This is the link to the library.
    https://github.com/jeremysf/Eagle-Libraries?files=1
    https://www.element14.com/community/message/173890
    Try this. You may prefer the way they have done the 49th pin
    https://www.dropbox.com/s/i2unz13wbn70kwj/NordicSemi.lbr
    This is all happening in the wrong forum so should stop.
    Warren
  • clem57
    Agreed. See https://www.snapeda.com/parts/NRF51822-BEACON/Nordic%20Semiconductor/view-part/
    I would delete that library and project first. Then install this https://github.com/ThoughtWorkshop/eagle-libraries/tree/master/PTR5518
    a look alike or goto nRF51822 Evaluation Kit / Bluetooth Smart/Bluetooth low energy / Products / Home - Ultra Low Power Wireless Solutions fr…
    reference layout for gerber files to import into eagle.
    Clem
    0 shabaz over 10 years ago in reply to e14 Contributor
    Hi Rahul,
    The datasheet shows there are 49 pins (48 + pad)..
    Still don't see what the issue is..
    It states:
    The exposed center pad of the QFN48 package must be connected to ground for proper device operation.
    I have attached the library link. As per my understanding in the nrf51822 there is only 48 pins.
    Hi ,
    I think the VSS is an extra pin in this library. The package used is QFN48
    This is the link to the library.image
