EAGLE User Support (English) [BUG] Differential pairs do not include entire traces
  • Subscribers 189 subscribers
  • Views 510 views
  • differential pairs
xxxajk
xxxajk over 10 years ago
Seems that only a matching segment of a pair is compared. This makes meander nearly useless, especially if one trace is a single segment.
The correct way is to compare the entire trace lengths including any curves.
  • xxxajk
    0 xxxajk over 10 years ago in reply to clem57
    Figured it out.
    UNFORTUNATELY the DEFAULT is not anything anyone would want for a differential pair.
    Mouse keys
    Ctrl+Left measures the length of the selected signal segment.
    Ctrl+Shift+Left measures the maximum length of the selected signal segments.
    Right toggles between symmetrical and asymmetrical meanders.
    Augh!
    Also the documentation on how to do things on the command entry mode is too terse. Some examples in the help files would be very helpful, as well as actually showing the full syntax.
    Syntax
    MEANDER [length] • ..
    This doesn't give one much information on what to do. Come on, let's do better. I did pay for this product.
  • xxxajk
    Only _ONE_ trace (the shorter one) should meander, not both.
  • clem57
    0 clem57 over 10 years ago
    Differential routing / meander issues
