EAGLE User Support (English) Turn off thermals on selected components
  • Replies 13 replies
  • Subscribers 189 subscribers
  • Views 3393 views
zainka
zainka over 10 years ago
Hi
I have a design with several press-fit connectors. For these to turn off thermals would be a benefit. However, for other components which are soldered, thermals are required.
Is it possible to turn off thermals for individual components but leave them on for others?.
Thanks in advance
Vidar
  • rachaelp
    0 rachaelp over 10 years ago in reply to zainka
    Hi Vidar,
    A thermal option checkbox for each component is probably a reasonable suggestion. In addition to this I was thinking possibly it could also be something that is specified as part of the library part? After all, that press fit connector will want to not have thermals wherever it is used, so that info should really be stored with the part in the library I would think.
    Best Regards,
    Rachael
  • zainka
    0 zainka over 10 years ago in reply to autodeskguest
    Yes, that is an option, but I would prefer something that did not involve tweaking or workarounds.
    I have 5 pressfit connectors with 916 pin in total on a board with 14 layers. Many polygons in other words.
    I will suggest (in suggestion group) adding an thermal option / checkbox to component info-window, but i fear that will require a major code rewrite.
    Vidar (Z)
    In such cases, I simply draw multiple (overlapping) polygons with
    different "thermal" properties.
    Tilmann
