EAGLE User Support (English) Using a box around the circuit diagram
  • Subscribers 189 subscribers
  • Views 859 views
matelot
matelot over 10 years ago
is there any way from within eagle to print circuit diagrams in one of those boxes that you usually see circuit diagrams in with all the information in small boxes in the bottom right corner?
I'm sure someone will tell me what they are called.
  • matelot
    0 matelot over 10 years ago in reply to autodeskguest
    for some reason my first reply loaded as 'cadsoft guest' and now I can't delete it?
    Please ignore this reply, I have the section now.
  • matelot
    0 matelot over 10 years ago in reply to shabaz
    Sorry for the delay. I have been neglecting the circuit diagrams for some time.
    This is just what I wanted.
    For some reason the A4 frames are nowhere near the edge of the paper and my circuit diagrams extend beyond the edges but the TABL-L is ideal, I haven't had a really good look at the other frames, I will some day but this does exactly what I want, it even changes the time and date on the sheet when I save it.
    The one marked      FRAME_B_L    is even better.
    Thanks shabaz.
    0 autodeskguest over 10 years ago in reply to shabaz
    I can't find a 'frames' library in eagle? can you show me where it is?
    https://www.element14.com/community/message/200886
    0 shabaz over 10 years ago
    I think you're referring to a frame, and title block.. these are available in the 'frames' standard library supplied in EAGLE.
