EAGLE User Support (English) rename multiple vias at the same time
  • Subscribers 187 subscribers
  • Views 2972 views
  • name
  • vias
I am placing multiple vias next to each other in order to electrically connect two polygons (top and bottom) of the same net. When placing the vias, each one has a unique name. Hence, the vias are not connected to the polygons. So I am using the name-tool now to rename each via one by one. The group-function does not work.
Is there a faster way of renaming the vias so all of them are within the same net as the polygons at once? Maybe directly when placing them?
Thank you!
Lars
    0 autodeskguest over 10 years ago in reply to autodeskguest
    Tilmann Reh wrote:
    P.S. HELP works.
    and even helps 8-)
    Lorenz
    them?
    Exactly, directly when placing them:
    VIA 'GND' klick klick klick klick ...
    Tilmann
    P.S. HELP works.
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    Thanks for that easy solution image
    On 07/07/2016 03:52 AM, Lars Middelstaedt wrote:
    Thank you!
    Lars
    https://www.element14.com/community/message/200935
    Place the first via with the same net name as the polygon then copy the via to other places. The copies will retain the
    net name as long as the via doesn't use an Eagle generated name. You can then copy the copies as you would the first via.
    Eric
