EAGLE User Support (English) I'm stuck, can't even open a .brd
  • Replies 10 replies
  • Views 1479 views
I've just installed v7.4.0 free at Linux x86_64. My very first try was to open a .brd dl'ed from the net, just for program function testing.
It responded with a small window (error message?) visible for less than half a second, then quit. Impossible to catch.
Same reaction with a .sch
Any idea, anyone, how to catch it anyway?
Grtz, Soeren
    0 e14 Contributor over 10 years ago in reply to autodeskguest
    I just upgraded Eagle from v7.4.0 to v7.6.0
    Problem gone, now .brd files open as expected
    Many thanks to all commenters.
    Greetings, Soeren
    0 autodeskguest over 10 years ago in reply to e14 Contributor
    Am 20.07.2016 um 20:48 schrieb Soren Poulsen:
    Hi Guest again,
    Please skip my former comment:
    I have now entered Eagle as root, selected a freeware license, and restarted. Trying to open a .brd made the same small elusive window appear shortly.
    Still perplexed ...
    Soeren
    https://www.element14.com/community/message/201961
    hi Soeren,
    the file you sent is okay. It's a V5 file that can be loaded here
    without any problems.
    Can you give me more details about your linux? Which system, window
    manager?
    Richard Hammerl
    Hi Guest again,
    Still perplexed ...
    Soeren
    If it is not top secret you should attach your file here. Then eagle
    users can check what's going on with that file. Mostly this is more
    effective than all this chatting, because right now we don't know if the
    file is the problem or your installation.
    Joern Paschedag
    Addendum
    Poking around within the demo's, I came to three .brd files under tutorial (projects -> examples -> tutorial).
    demo2.brd and demo3.brd opened as expected. But hexapodu.brd bombed and Eagle quitted abruptly just like described above.
    More mysticism.
    Soeren
    I invoke Eagle with Control Panel to the left.
    I then open a .brd file and browse to a filename.brd. On selecting this file, elusive window appears, Eagle quits. Apparently the same reaction both before and after licensing. Suspicious-looking, am I licensed or not?
    Overall, about this license procedure: Exact same license text (shown above in my cancelled remark) shows up, both on a fresh Eagle, and after su-licensing. There is no ident following "Registered to:", just empty space. Thus, no unambiguous info on launch: a text just showing licenced or not licensed would do. Puzzling.
    My headline still applies.
    Soeren
    OK, so you've eliminated that. How are you launching Eagle? Have you
    tried just invoking it, without attempting to open a board? Do you get
    the control panel then?
    Hi Guest again,
    Still perplexed ...
    Soeren
    Hi Guest,
    Here is - at the start of that VERY FIRST RUN - what I understand as a license confirmation. It appeared almost by itself.
    Single User License #62191E841E-LSR-WLM-1EL
    FOR EDUCATIONAL USE ONLY!
    Registered to:
    Freeware license for "non-profit"
    and evaluation purposes. See the
    file "freeware.key" or the URL
    "www.cadsoft.de/freeware.htm"
    It appears anytime I launch Eagle so far, and I haven't involved any su-operations.
    I'm still mystified ...
    Soeren
    Random thought - was that actually the VERY FIRST THING you did after
    installing? Because if so, it's wrong. You need to run Eagle, just once,
    as root so that you can select the license type ("free" in your case),
    otherwise it won't run as a normal user.
    Am 20.07.2016 um 15:05 schrieb Soren Poulsen:
    Grtz, Soeren
    https://www.element14.com/community/message/201901
    can you load one of the example project files?
    Maybe you want to send the files you want to load by email to me. So
    I could check....
    Richard Hammerl
