EAGLE User Support (English) Moving a Library to a Folder
  • Answers 2 answers
  • Views 2070 views
  • eagle
  • organisation
  • library
R_y_a_n
R_y_a_n over 10 years ago
It would be nice to move some libraries into folders to keep them organised.
But as soon as I move a library, when I try to use a part in that library (e.g. update a package), Eagle tells me:
Library Connector.lbr was not found in current library path(s).
Please adjust the library paths or export the drawing libraries first!
Is there any way to move a library to a folder and still keep the references?
~R
  • R_y_a_n
    0 R_y_a_n over 10 years ago in reply to geralds
    Thanks, Gerald and Joern!
    This worked great.
  • geralds
    0 geralds over 10 years ago in reply to autodeskguest
    yes,
    thanks for the addition.
    I forgot to mention this.
    Gerald
    0 autodeskguest over 10 years ago in reply to geralds
    Am 27.07.2016 um 16:09 schrieb Gerald Schwarz:
    yes, this is very easy to use.
    -> in the control panel you'll find the menu item options - folders:
    in this Formular you can register your own lib folder you like.
    I have it so in example:
    C: - the eagle program
    D: - projects with the library folders.
    !! Then if the folders are registered you needs to activate all needing lbr files in the program panel.
    Regards
    Gerald
    https://www.element14.com/community/message/202430
    In addition you can add more paths be separating them by a semicolon.
    Joern Paschedag
  • geralds
    I have it so as an example:
    For the future: if you makes some updates or upgrades the program will copied in there new folder.
    Then you have playing same the game manually moving the lbr folders.
    Regards
    Gerald
