EAGLE User Support (English) Creating via causes X over the via
  • Subscribers 187 subscribers
  • Views 732 views
weswitt
weswitt over 10 years ago
I must be doing something obviously wrong, but all vias that I create have big X through them. Can't seem to figure out what to do to create a correct via. Any help would be great.
    "Wes Witt"  wrote in message
    news:1177327588.01472528829399.JavaMail.jive@e14-cr-vp-appj8-01.premierfarnell.net...
    via. Any help >would be great.
    Check your stackup too. Does the via go trough all layers (1-16)? I'm
    thinking maybe you messed the stackup to do stacked vias.
    0 autodeskguest over 10 years ago in reply to autodeskguest
    On 30/08/16 07:29, Lorenz wrote:
    And: don't use the wire command to draw your traces. Use the net
    command.
    "route" command. "net" is the schematic one.
    command.
    the cross stands for a vertical air wire.
    I assume you're routing a net and now have traces in different layers
    with overlapping ends.
    And it seems, you are trying to create the vias manually.
    In this case you need to enter the net name one command line (either
    after activating the via command by clicking, or directly by entering
    "via 'netname " on the command line.
    But:
    vias are created automatically during routing by changing the layer,
    either by selecting one from the drop down menu in the tool bar, or by
    clicking the middle mouse button.
    command.
    Lorenz
    https://www.element14.com/community/message/204776
    Hi
    I'm guessing that, if you move the via, the big X will remain and is at
    a point where two wires, with the same name, on different layers end. It
    represents an airwire of zero length. i.e. from one layer to another
    vertically.
    In your situation I suspect the Vias need to be named so give them the
    name of the routed traces that end at the X.
    The manual covers generating named vias automatically as you route by
    changing layers with the mouse scroll click centre button or alternately
    Shift Click when you terminate a route at the same point as a wire of
    the same name on a different layer.
    Get into some tutorials and reduce your grief
    HTH
    Warren
