EAGLE User Support (English) Editing eagle library
  • Subscribers 189 subscribers
  • Views 1398 views
maciv4
maciv4 over 10 years ago
I'm having problems with an eagle library I have created. Every time I edit the library to correct the problem nothing seems to change. I have tried everything I can think of and in every combination. I have check all the tutorials they don't cover the problems that I have. Can anybody help!
I have posted the files at the following site:
http://sabercathost.com/13Q8/1.2V_PSU_NQR010A0X.pdf
http://sabercathost.com/13Q9/lineage-power.lbr
http://sabercathost.com/2jSS/power-module-1.2v.lbr
    0 autodeskguest over 10 years ago in reply to maciv4
    Does the DRC file alter the library? I thought that this was a filter to find problems, not something that would adjust a library. Am I wrong?
    https://www.element14.com/community/message/204928
    Hi Jim,
    I hope you're doing well. You didn't give an exact description of what
    you were seeing by judging by your question I think Rachael nailed it on
    the head.
    First some explanations are in order:
    The Restring tab of the DRC is likely what is causing your through hole
    pads to be larger on the board than what you specified in the library.
    The intent of this feature is noble, however since it's behavior is not
    expected it tends to create confusion. The goal of the restring function
    is to make sure that the annular rings on through holes pads and vias is
    thick enough for the pad to survive an off-center drilling by the
    manufacturer. Everything in the real world has a tolerance, and with
    some manufacturer's the tolerances on drill locations are actually very
    wide. If a drill is so off that it passes the outside diameter of the
    pad, the pad will break and will no longer be reliable.
    Because this can be such a critical manufacturing issue, the DRC
    Restring is always in play. EAGLE will compare the pad diameter
    calculated by the DRC to whatever you specified in the library. The
    LARGER of the two wins. In your case the the diameter you specified in
    the library for the diameter of the pads is too small and the DRC bumps
    it up to conform to the default design rules.
    So what's the solution?
    The best thing to do here is to adjust the restring settings to match
    whatever your board manufacturer requires. If you do that then assuming
    your board house can make the thinner annular rings you want the pads
    will not be changed. If the board house can't handle it then you'll see
    the annular rings swell again and you'll have to talk to your manufacturer.
    Please let me know if there's anything else I can do for you.
    Best Regards,
    Jorge Garcia
    Am 01.09.2016 um 21:27 schrieb Jim McAuley:
    http://sabercathost.com/13Q8/1.2V_PSU_NQR010A0X.pdf (https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fsabercathost.com%2F13Q8%2F1.2V_PSU_NQR010A0X.pdf)
    http://sabercathost.com/13Q9/lineage-power.lbr (https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fsabercathost.com%2F13Q9%2Flineage-power.lbr)
    http://sabercathost.com/2jSS/power-module-1.2v.lbr (https://www.element14.com/community/external-link.jspa?url=http%3A%2F%2Fsabercathost.com%2F2jSS%2Fpower-module-1.2v.lbr)
    https://www.element14.com/community/message/204921
    All these lists are for the birds.
    Place your library here so users can analyse it and describe what is
    wrong with it
    or what you wish to change.
    Joern Paschedag
  • rachaelp
    0 rachaelp over 10 years ago in reply to maciv4
    The DRC setting can cause a difference between the library and the board. It's an annoying "feature". For example the restring setting can cause a through hole pad to appear larger in the board than in the library.
    Best Regards,
    Rachael
  • maciv4
    0 maciv4 over 10 years ago
    I have:
    placed the pads
    realigned the pads
    resized the pads
    saved the library
    updated the library
    deleted the pads
    replaced the pads
    resized the pads
    saved the library
    updated the library
    repeated these steps over 10 times for each library to the point that I no longer have any clue as to what I have done, or what doesn't work, or what is causing the problem. I have read almost every tutorial, and link I can find to fix this. I can't that's why I am asking.
    0 shabaz over 10 years ago
    Hi Jim,
    Did you follow the "Editing and Updating Components" section in the EAGLE user manual?
    Did you click on Update as described there, after editing and saving the library?
    Without seeing a list of the steps you took, it is only possible to vaguely guess what you may or may not
    have missed.
    With little information, the answers can only have a simple response that may not apply to your specific scenario.
