EAGLE User Support (English) Wire to Net Conundrum.
  • Subscribers 187 subscribers
  • Views 286 views
yahalimu
yahalimu over 10 years ago
I have been using Eagle 7.6 Light to design the schematic for my project, I have no previous Eagle experience.
Much later and now I am close to getting the PCB made I have started to follow the tutorial and look at the manual.
I have discovered I should have used NET to connect to component pins rather than WIRE.
Does anyone know a quick and easy way to change them all to NET without replacing each connection one by one?
Iain
    Well, that'll teach you image
    Fortunately you probably don't need to. Although the NET tool is the
    correct one to use - because it does the right thing in lots of cases
    where WIRE doesn't - Eagle is smart enough to register wires in the
    "Nets" layer as creating nets too, provided they make the required
    connections.
    You say you're "close to getting the PCB made" so I assume you've got a
    board layout? You must have had the airwires when you started that,
    which demonstrates that the nets have been created. Check your ERC
    results to be sure there are no unconnected pins and visually review
    your board to confirm that it's complete.
