EAGLE User Support (English) How to group objects then select them as a group
  • Views 750 views
Hi, i want to know if i can group objects and give them some kind of indicator, name etc. then select them as a group easily with that indicator.
    0 autodeskguest over 10 years ago in reply to rachaelp
    indicator.
    No unfortunately the group function in EAGLE does not work that way.
    There is a ULP around that somebody on here wrote (I think it's called
    something like pickgrouped.ulp) which allows you to select a group of
    components in the schematic and then when you run the ULP you have the
    corresponding parts selected and moving in you board editor, this
    might help you out if your schematics have things drawn in sensible
    groups.
    'someone' in this case is me 8-), but pickgrouped.ulp is for picking
    up parts in the board editor, that were grouped in the schematic
    editor.
    But it should be relatively straightforward to write an ulp that saves
    the information about grouped objects to a file (or to eaglerc.usr).
    Lorenz
  • rachaelp
    0 rachaelp over 10 years ago
    No unfortunately the group function in EAGLE does not work that way. There is a ULP around that somebody on here wrote (I think it's called something like pickgrouped.ulp) which allows you to select a group of components in the schematic and then when you run the ULP you have the corresponding parts selected and moving in you board editor, this might help you out if your schematics have things drawn in sensible groups.
    Best Regards,
    Rachael
    No, this is not supported in 7.x, but I think its a good idea. There
    might be trolls tho, in which/how wires move with the objects.
