EAGLE User Support (English) Where can I find a logic level N-channel mosfet that is smd. Need min. 20V and 500mA, working on a 3.3V based atmel chip.
  • Views 1053 views
ctech83
ctech83 over 10 years ago
I've found the  FQP30N06LFQP30N06L which is TO-220 package I need an alternative that is smd I'm going to control a 12V pump that will have max 400mA It will be controlled by an atmel chip running on 3.3V so it needs to be logic level Any suggestions
  • jameslittlefield
    0 jameslittlefield over 10 years ago
    FDC6401N maybe?
  • dukepro
    0 dukepro over 10 years ago
    On 10/05/2016 01:04 PM, Christian Simonsen wrote:
    I've found the FQP30N06L which is TO-220 package. I need an alternative that is smd.
    Go to mouser.com.  Follow the links to Semiconductors -> Discrete
    Semiconductors -> Transistors -> MOSFET.
    Then do a parametric search.
    BTW, This newsgroup supports Eagle CAD software.
    On 6/10/2016 6:04 a.m., Christian Simonsen wrote:
    I've found the FQP30N06L which is TO-220 package. I need an alternative that is smd. I'm going to control a 12V pump that will have max 400mA. It will be controlled by an atmel chip running on 3.3V, so it needs to be logic level. Any suggestions?
    https://www.element14.com/community/message/206970
    Please;
    This a forum for support for EagleCad pcb software. Not an electronics
    101 forum
    Please ask your qurestion in a more appropriate place.
    Thank you
    Waren
