EAGLE User Support (English) How make V-cut line in Eagle?
  • Subscribers 187 subscribers
  • Views 4906 views
  • eagle
  • panelize
  • v-cut
jltharin
jltharin over 9 years ago
Hi everybody!
I would like create some V-cut on PCB. How should I do it in Eagle? Which layer. etc?
Thanks in advance!
Eagle 7.6.0 on Win10
    0 autodeskguest over 9 years ago
    I've been just using layer 20 to show the board edge and specify Vgroove in
    the readme. The board house then will adjust routing or Vgroove to best fit
    their process.
    "Jean-Louis Tharin"  wrote in message
    news:1205032693.131476447142041.JavaMail.jive@e14-cr-vp-appj8-02.premierfarnell.net...
    Hi everybody!
    layer. etc?
    Thanks in advance!
    https://www.element14.com/community/message/207385
    There is no predefined layer.
    You might define a new one (I often define layer 148 "vscore") and draw
    thin lines in it. Then provide the gerber data to the board house, along
    with all other files.
    Many board houses automatically convert outlines (in the milling layer)
    that are within a panel to v-scoring data - provided you told them that
    the panel is to be scored.
    It's always a good idea to talk to your board house and confirm the data
    they prefer (or at least can process).
    Tilmann
    On 14.10.2016 14:11, Jean-Louis Tharin wrote:
    Hi everybody!
    Thanks in advance!
    Afaics, Eagle has no predefined layer for vcut.
    Basically you have to make your own layer and draw it there. Of course
    you have to send this layer to the manufacturer and tell them that it is
    vcut data. If you use the CAM processor to generate your output, you
    have to make sure to add a job to extract this data.
    If this is too advanced for you, you should just make your pcb and tell
    your manufacturer to panelize them and use a vcut for separation. I
    guess thats what you want to use vcut for.
