EAGLE User Support (English) gap between polygon fill and milling
  • Subscribers 187 subscribers
  • Views 763 views
Dwayne@2DKits.com
Dwayne@2DKits.com over 9 years ago
I have a board with a polygon fill and milling. How do I setup a gap between the Polygon fill and the milling cutout? Right now the fill goes all the way up to the milling.
    0 autodeskguest over 9 years ago
    Outlines in the milling layer are not recognized by the polygons - and
    this is fine, since otherwise you can't produce metallized slots.
    If you want the polygon to stay away from the milling, draw the outline
    in the dimension layer as well. There's a DRC setting for the distance
    between copper and dimension that will be used.
    Tilmann
