EAGLE User Support (English) Import dxf as boundary of ground plane polygon?
  • Subscribers 187 subscribers
  • Views 842 views
ogrecrusher
ogrecrusher over 9 years ago
I'm aware of how to import a solid pour from a dxf file, but is it possible to use a oddly shaped "circle" as a ground polygon which will automatically isolate from vias etc?
The shape has lots of odd partial arcs and tracing over it manually has been hard as it's not possible to edit the radius of curvature of an arc section after drawing it.
Lucien
    0 autodeskguest over 9 years ago
    Lucien Copus wrote on Mon, 17 October 2016 23:37
    ....The shape has lots of odd partial arcs and tracing over it manually
    You can change the end points of the arc with the move command. You can
    change the curve with the CTL + MOVE and clicking at the middle of the arc,
    then drag.
    HTH
    Warren
    Hello Lucien,
    I hope you're doing well. Try the import-dxf-1_6.ulp which is a
    combination of two other ulps, one of them can import DXF files as a
    polygon outline allowing you to make the appropriate copper pour.
    You can find the ULP at www.cadsoft.io > Resources > User Language Programs.
    Best Regards,
    Jorge Garcia
